Results 1 to 11 of 11
Thread: RPM signal wire
    VS ute
    Nov 2009
    Default RPM signal wire
    Hi guys ive just become a member here and i need a little help with my VS manual ute i just bought a tacho to put in it but im having trouble finding the RPM signal wire, i was wondering if anyone could let me know where it is or if you know where i can find a wiring diagrom on the net or something.
    thanks
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    um from memory its negitive brown and under the bonet on the drivers side. i will try and find a pic for you.
    EDIT. its in the gray thingie
    VS ute
    Nov 2009
    Sep 2008
    VS ute
    Nov 2009
    i just had a look theres two browns going in and out of that grey box is it one of those?
    VS ute
    Nov 2009
    ok thats awsome thanks alot that healps heaps!!! so do i connect it to the brown one there?
    Sep 2008
    your welcome .
    there are two brown wires one is positive the other one is negitive, the rpm wire goes into the negitive.
    also i made this ages ago have a lookit might be helpfull : TACHO instal by Fuzzy
    VS ute
    Nov 2009
    Sep 2008
    VP Exec
    Jun 2005
    An alternative point to pick up the signal wire is at the connector located exactly as described in the install instructions reproduced in the "How To"; in the harness that runs along inside the guard on the passenger side of the engine bay. It's a brown wire with a single white female connector on the end of it. I think that the connector is the same type as that used for the immobiliser LED on VP (to help ID it).
    On a V6 the wire connects to the DFI at pin "E" - 3 connector terminal positions from the centre of the DFI terminal connector - still brown in colour - so you could tap into that directly.
    Even easier may be to connect into it at the wire going to the leftmost connector that the instrument cluster plugs into. The wire should be at the topmost, rightmost position of the connector and brown with a red trace. I've used that on my VP Exec. and it should still be usable on a VS.
    2009 VE SS UTE
    Jun 2009
    Emerald
    Hey
    I have a vy s and I connected the signal wire to the negative brown and the Tacho won't work, I tried a range o different wires and still nothing any help would be great
    Ps. I know I have one in my dash cluster but I still want it
  1. water temp/oil psi signal wire
    By sycvs in forum Electrical Wiring / Questions
    Last Post: 07-11-2009, 01:53 PM
  2. tacho question (signal wire???)
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 11:00 PM
  3. head unit signal wire
    By maxpower QLD in forum Car Audio
    Last Post: 13-07-2008, 05:40 AM
  4. signal wire for air fuel gauge
    By guyver6 in forum Electrical Wiring / Questions
    Last Post: 09-10-2006, 08:49 AM
  5. MAP signal wire
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 04:19 PM
