Results 1 to 6 of 6
Thread: plastic heater junction can i bypass ?
    vx berlina
    Aug 2005
    gladstone
    Exclamation plastic heater junction can i bypass ?
    hey guys was changing my sparkplugs on my vs just b4 and i just tapped one of the heater hoses that goes into a plastic junction like thing where 4 heater hoses join onto in front of the brake booster . anyway one of the plastic joins just snapped from heat and age so im wondering can i just block off these 4 heater hoses as i do not use my heater it wouldnt worry me and i no that this plastic tube shaped juntion thingy would b expensive and hard to get where i am ? any ideas cheers muz
    Attached Thumbnails Attached Thumbnails plastic heater junction can i bypass ?-100_0935.jpg
    vs commodore
    Oct 2009
    Tamworth NSW
    I bought a new heater tap(the thing you have broken) complete from holden .about $60.Just bypass it for now.
    vx berlina
    Aug 2005
    gladstone
    hey guys its all good i just bent the hose from the motor around in a u shape and attached it back to the motor just bypassing the heater tap as i said i dont ever use heat anyway cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    Exactly what I did when mine broke.too easy.Also I wouldnt leave it like that for too long,The heater core has no coolant going through it and will rust away in no time.Big job, like the whole dash out to replace it.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Remember that it is a requirement that your vehicle has a working demister. By disabling the heater you may in fact be in breach of ADR requirements. Might sound 'pedantic' but these safety improvements were put in place for a reason.
    Any (ANY) modification(s), unless approved to ADR standards, that change/alter/modify any aspect of your vehicle from the ADR standards/requirements that existed at the time of manufacture of your vehicle are ILLEGAL.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    benboy are you trying to give keepleft a run for his money in being pedantic? all your posts lately have been complete dribble. unless you're going to offer him information on how to do what he's asking, just keep it to yourself.
    You're right, everything is illegal, hell even getting rims 2 inches bigger than stock is illegal. Just do us a favour, and take yourself to the todaytonight or a current affair forums, where you'll fit in with the rest of the wowsers.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. bypass fan for my v6?
    By vn_v6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2009, 03:45 PM
  2. Bypass heater
    By spudd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2008, 07:27 PM
  3. Replies: 10
    Last Post: 24-07-2008, 04:59 PM
  4. removal of plastic above Radio/AC Surround plastic
    By jayderichards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 09:28 AM
  5. bypass
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 10:41 AM
