I think all of it will except for the stepper motor which will have a different cable length and also the clip at the end of the cable is probably different. Another problem may be whether the VR has the wiring already there. But the relay, stop switch, indicator arm should be OK. Stepper motor internal are probably identical...just the cable is the problem (but I think that can be overcome)
