just bought myself a vs s2 super6 calais.
just niticed that the airbag light doesn't light up when you switch the car onto the on position.
You know when u switch the car on and all teh ligths show up for a couple of seconds well my abs light doesn't, checked the bulb and the bulbs fine. have checked the fuse and thats also fine.
Next step is a whole lot of reading lol checking the wire diagram.
Just wanted to know if anyone else has had this issue and knows a preferably easy fix =D
the aribags have never been deployed and its never been in a crash.
Any ideas?
Hi,you need to see someone with a scantool that can read to/from the SRS Module.It is probably a faulty module or a break in the wiring,which they should be able to tell you where or what it is that is faulty.Theres no real way to test it yourself.
yea im gunna chuck it on tech1 2morrow or monday. see what codes it showing
That will certainly do the trick.Cheers
Does anyone know where the air bag module relay is?
Its under the drivers seat in the VS sedan.Just look under the driver seat and you will see a black box.Thats it.I wouldnt muck around with it,it might set off the airbags.Just saw that you said relay.Its under the dash near the fuses and other relays.Its the SRS Module thats under the seat.
yea cool. im not worried father in-laws a holden tech we should be able to sort it out. just been soo long sincehe has worked on a vs
AHA sorted it out.
The light is on its on all the time, theres a fault.
Some wise bastard had covered it up with electrical tape so you couldn't see that it was on....
Good one,cheers.
Found the Fault now, Its a earth some where between the dtc connector the bulb and thelast plug in the circuit to the srs module. i have a wiring diargram only problem is what i have infront of me is different to the diagram????!!!?? Does anyone have a more up to date SRS wiring diagram for a s2 1997 vs calais
Thats out of my VR Manual, Might be the same?
R.I.P dynoryder
Thanks for that mate i was just looking for the srs circut wiring diagram but yea have a vr/vs one and its different then wat i can see under the dash doing my bloody head in...but thanks heaps for digging that up for me anyways mate
[/IMG]
This one is a bit different from the other one posted above.Its got the passenger airbag included.VS manual
LOL put it all back together so i could plug tech1 into it, cleared all the codes then started her up checked the codes and she was all sweet dunno what happened but no more fault.....must have moved the wires around to enuff to stop the earth fingers crossed it wont come back =D
