Results 1 to 14 of 14
Thread: anyone ever change the lights on the eurovox stereo?
    vs calais
    Dec 2008
    Default anyone ever change the lights on the eurovox stereo?
    well about a month ago 1 or 2 of the backlights on the eurovox original stereo blew and now the screen backlight has gone too!
    has anyone ever changed these and can give me some tips.... how and how hard is the radio to pull apart??
    it is the calais version of the eurovox
    cheers
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Just get a new stereo... It's so much more better...
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    vs calais
    Dec 2008
    ye its my fathers car, all original, and want to keep it that way
    anyone have any advice?
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    buy a second hand eurovox unit from a wreckers or eBay. (shouldn't cost more than $50?)
    I've never heard of anyone replacing the lights in the HU, as most people upgrade to a new stereo.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by DeiCide View Post
    If you do that, make sure you get the security code otherwise it will only be good as a door stop.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've replaced bulbs on other radios from Fords etc and found I had to separate the front panel from the main radio chassis - done by a few screws and wiring connectors...the actual bulbs will be tiny, about the size of a matchhead and be soldered onto the front panel/circuit board. It is do-able if you are prepared to take the time and trouble. If you do try it make sure you take digital pix for re-assembly.
    Another stereo from a Calais may also have the same problem. Jaycar should have bulbs although I scavenged mine from other old radios which had the digital fronts. Good Luck.
    vs calais
    Dec 2008
    ye thanks hako
    im more interested in trying to replace the bulbs... want to keep it all original
    anyone else who has done a commodore eurovox?
    VY SS
    Jun 2006
    Albany
    if i was you i would prob try to find a second hand one and pull that apart first and pinch the globes from that, that way you can get an idea on how to pull it apart first without having to worry about breaking your original on
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Yeah I replaced the one in the display in my Eurovox. It blew when i had a dodgy brake globe and the parkers kept flashing on and off every time a touched the brakes.
    Anyway, what i did and recommend you consider is replaced it with a green LED ( and suitable resistor in series to drop the voltage ). The mini 12V globe as per original are very hard to find which is another reason to go LED. The raido is easy to pull apart once you get it out of the dash.
    Super Coach's Avatar
    Super Coach is offline VS S Pak, Monaro CV8Z
    VS Commodore S, VZ Monaro CV8Z
    Jul 2006
    Hey guys im stuck need some help. I've pulled the radio apart the only thing stopping me pulling the front facia off the radio is the two knobs (VS S PAK) how do you pull the kobs off without breaking it?
    Super Coach
    Jul 2006
    ok so I have pulled and tugged at the knobs on the radio and still cant get them off. Do I need a special tool or something or are they glued on? Because I dont want to break, scratch the front of the facia. Any advice I would be greatful for.
    Super Coach
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Can't remember but i reckon you just pull them off. Unless a previous owner has glued them ?
    Jul 2006
    ok took a while some screw drivers and mighty grips but they are off and nothing is damaged thank goodness. Will post up a pic of what it looks like for those interested now just to find a good electronics place to fix the little lights!
    Super Coach
    vs calais
    Dec 2008
    please post that pic and any info that you might have to pull the face off.
    im still yet to do this, but need to badly!
  1. Eurovox stereo removal
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2009, 11:04 AM
  2. Eurovox Stereo Repairs
    By Sara Pax in forum Car Audio
    Last Post: 01-07-2008, 05:37 PM
  3. Ipod in my VX Eurovox stereo
    By drums1974 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 07:12 PM
  4. Stock Eurovox Stereo in VT
    By jacko in forum Car Audio
    Last Post: 08-04-2006, 09:51 PM
  5. Eurovox Stereo
    By beckrey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2004, 07:22 PM
