Results 1 to 6 of 6
Thread: Disabling air bag to remove front seat
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Default Disabling air bag to remove front seat
    Is this necessary ? I need to install a tailored made sheep skin seat cover and the Gregorys manual states to do this before you remove the drivers seat. I know that the box of "tricks" is mounted under the drivers seat but would doubt if it is connected to the in some way ?
    Mmmmm V8
    Vr BT1 5lt
    Jul 2009
    Frankston
    i pulled out my front seats and didnt disable the airbag but if your worried id just disconnect your battery
    Apr 2004
    vs commodore
    Oct 2009
    Tamworth NSW
    In the gregorys workshop manual it says to disconnect the battery ,remove fuse number 18 from the fuse box under the steering column.Also under the column is 1 or 2 yellow wiring connectors.(depending on whether theres a passenger airbag.)It goes on to say that these connectors should be undone as well.Theres a security pin in the passenger airbag connector.Just remove it to unplug it.I think these have backup power(in case the battery gets disconnected/damaged in a crash.)Thats why it doesnt just say "disconnect the battery"
    Apr 2004
    Thanks Brett_jjj
    I must admit I have gone through that procedure before when I replaced the steering wheel with a leather bound one. I can appreciate doing it then, but I just thought it was a bit over the top to go through that just to remove the front seat.
    Mmmmm V8
    vs commodore
    Oct 2009
    Tamworth NSW
    I agree,A lot of stuffing around just to disable it.You would have to be unlucky to set it off when working on somthing else(like removing the seat).The only trouble Ive had is when I removed the SRS relay with the ignition switch on.(problem with the blinker relay)And it set an error and the light was on.Had to see someone with a scanner to get it turned off which cost me $30.
  1. How do you remove dickie seat brackets from a VS Wagon?
    By ant_1984 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2009, 02:40 PM
  2. Remove rear seat + parcel shelf speaker grills on VE?
    By stoogeman in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-06-2009, 03:49 PM
  3. remove rear seat in vx
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2008, 09:16 PM
  4. Replies: 3
    Last Post: 28-07-2008, 10:35 AM
  5. How to remove back seat
    By Flat_White in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-07-2008, 08:13 PM
