Im looking for a straight anwser here please lol as i have heard so much oposing info on this topic i cant seam to get a straight anwser on it.
I am putting a T5 box that came out of a VP into a VS SERIES I and i want to no if the flywheel out of a VP will fit a the VS Ecotec motor? Just want to no if holden used the same flywheels for both or did they make a special flywheel just for the VS's to run the T5 gearboxes before the Getrag was released? . Thanks
So whats the deal with all the stuff ive heard about the ecotecs needing a specially balanced flywheel or is all that a rumor?
Buick engines are externally balanced, ecotec's are internally balanced. So basically you SHOULD get the flywheel properly balanced for your engine.
