Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Just a few questions.
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Question Just a few questions.
    Well first one is... I feel stupid for this..
    What's the inlet manifold look like and where is it located?...
    Would my coolant problem be because of the inlet manifold gasket? No leaks, no coolant in engine...
    My Cruise control turns on but wont set a speed. Any ideas?
    My fuel pump makes the noise when you turn the key to "ON" but is still hard at starting cold. Ideas?
    What should I be doing for each 5000k service?
    Just trying to get ideas for each problem
    Feel like an idiot with half the stuff...
    I know a bit about cars but not everything.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Not that Im saying it isnt the inlet manifold gasket, (it could be) but it is possible for a head gasket to be stuffed without obvious signs like water in the motor.
    Normally at 5,000kms I just change my oil and oil filter (pedantic? yes.), check the water and brake fluid levels.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I dont want it to be a head gasket... Thats too much work...
    My Commy
    Discuss.
    vs commodore
    Oct 2009
    Tamworth NSW
    If you are removing the inlet manifold,theres not that much more to do to remove the heads.Undo the exhaust headers, you dont have to remove them(standard ones anyway),just pull em back from the head,and undo the head bolts and rocker gear.Id buy a gregorys workshop manual if you are going to do this,It is step by step, you cant go wrong, and when you put it back together you need to tension stuff up properly etc,its got all the right torque settings and stuff.You will also need a good tension (or torque) wrench.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Hopefully when I have my mate come over for some help he will bring a torque wrench... Haha.
    I'll try to get a gregory's manual as well... Always wanted to get one...
    My Commy
    Discuss.
    vs commodore
    Oct 2009
    Tamworth NSW
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I think, when I last looked at one it was like 45 or so...
    My Commy
    Discuss.
    vs commodore
    Oct 2009
    Tamworth NSW
    I paid around $30 at supercheap.I'd shop around.Some places are a rip off with their manuals
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Inlet manifold is smack ontop of the engine. The large bit that has intake runners which go up to the top chamber (plenum). It's highly likely your coolant is leaking through the intake manifold gasket. In both my and my mate's car this was the cause of coolant loss.
    With the cruise control check that the cable is actually connected to the throttle body. When setting the speed it can be a little difficult to get it to engage because the toggle switch is fiddly. make sure you understand which way to push the switch to engage it.
    By hard to start do you mean it cranks over 10 times before it fires or do you mean it cranks sluggishly? It may be your battery, injectors, CTS, CAS, etc.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Quote Originally Posted by maldotcom2 View Post
    Hmm...
    The battery is brand new so thats not it.. The injectors had injector cleaner go through them. Nothing changed...
    By hard starting, I mean that it takes longer than normal to crank over.
    Then when it does, you go for a drive, turn it off and then come back 20 - 30 hour later it starts straight away.
    I put my car into the mechanics today, they pressure checked it, was too warm, couldnt find any leaks...
    Taking it in Thursday, leaving it over night then there gonna check it Friday morning...
    Hopefully they diagnose the problem already!
    Well I kn ow from memory that Autobarn had them for 50 and so did Supercheap. I think Repco did too... So yea...
    Getting a 10% discount from Autobarn so thats ok I guess...
    I know the guys there and im a good customer. Hehe.
    With the cruise control, The cable is the one that gets pushed in at the throttle body yes? Thats all connected and looks fine...
    I've tryed fiddling with the cruise control and no go...
    My Commy
    Discuss.
    vs commodore
    Oct 2009
    Tamworth NSW
    The cruise control wires get broken where the indicator stalk/switch goes into the steering column.Its fairly common problem.Might be worth checking it out.The cruise control will turn on,but wont set.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    So maybe try pulling the indicator stalk out to fix it or get a new one?
    My Commy
    Discuss.
    vs commodore
    Oct 2009
    Tamworth NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    Someone else posted about it and they just soldered the wires back up.Thats what I'd be doing.(if that is the problem)
  15. #15
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Hmm... I'll try to find out if it is that problem when I get the time to...
    Hmm... Should I be worrying about the black around my exhaust or should it be fine?
    I sometimes give it a bit too much but yea...
    My Commy
    Discuss.
  16. #16
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Just bought a Gregory's manual today. Figure, I should just do both, the head and inlet manifold gaskets. There almost the same amount of work... So i'll save up, get the head and inlet manifold gasket and possibly go to my gf's uncle house and spend a day there to do it maybe. Or 2 days.
    My Commy
    Discuss.
  17. #17
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by Wombles View Post
    that would be the O2 sensor, i reckon mines on the fry atm and my exhaust is all sooty as well. like 1 week after cleaning and its dirty as crap, and yes im using more fuel than i want to.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
  18. #18
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    My fuel economy aint too bad.
    It gets roughly 450k's to a tank. Which includes hooning (Getting off the line in a hurry and revving it high but doing speed limits), town driving and highway driving.
    My Commy
    Discuss.
  19. #19
    ve ss
    Dec 2009
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    im about the same but i know they can get alot better, specially considering my EF falcon was getting nearly 800 per tank lol.
  21. #21
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by q2cmee View Post
    How to put a tow bar on a ve ss
    wrong thread buddy
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  22. #22
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Quote Originally Posted by Paiste402 View Post
    800?!?
    When I had my dads EF Fairmont, it would strugle to get near 400. Haha.
    I thought my car went pretty good on fuel. Haha. May need to invest in a multimeter and shit and start doing tests on me car... Haha
    My Commy
    Discuss.
  23. #23
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    800?!?
    haha yea this was an EF Futura, not as heavy as the Fairmont. But i did mostly country driving, although there were alot of hills as well. I just serviced it and made sure it was running as good as i could get it and not too crazy on the right pedal. Get the O2 sensor looked at and give ur car a good service (with GOOD oil, cheap crap is nasty for ur motor and increases fuel usage a tiny bit due to added friction, Penrite HPR for the win) with a throttle body clean and u will be surprised but ur car can get per tank.
  24. #24
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    It has had a throttle body clean (May need to be taken off and cleaned properly).
    Needs a good engine service... Had one 3 thousand k's ago then i'll buy excellent oil for it.
    Giving it a wonderful transmission service which is most likely needed to remove the rough changes (Almost changes like a manual when it's auto. Haha.)
    That will be done this W/E hopefully.
    My Commy
    Discuss.
  25. #25
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    haha nice man keep us posted
  1. LPG Questions
    By JD in forum General
    Last Post: 04-10-2007, 04:07 PM
  2. cam questions
    By Philthy in forum V6 Development And Modification
    Last Post: 03-02-2007, 11:44 AM
  3. VS Questions????
    By Graza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2007, 10:00 PM
  4. VC questions again!
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-01-2007, 05:22 PM
  5. just a few questions........
    By DANVSUTE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-01-2007, 04:12 PM
