Results 1 to 8 of 8
Thread: VS Instrument cluster removed/refitted. Now issues
    VSII V6 Auto Berlina Wagon, VY SS Crewman
    Oct 2007
    Default VS Instrument cluster removed/refitted. Now issues
    Hi all,
    Re: VSII Berlina - Level 3 dash, Climate Control...
    Wondering if anyone could help me out. I have prolly jumped in too deep without researching enough!
    I had to check warning light bulbs in my dash as my high beam light wasn't working. After searching the forum I found a thread about instrument cluster lights so I removed my cluster.
    After refitting everything, my LCD screens now are not operational. Also, my Climate Control is going weird where the fan is running on 2 all the time - it still seems to work OK, but is on 2 when you turn it off. (Also, my Air Bag light is also on, but that is coz I was dumb and turned the ignition on when the cluster was out.) I have pulled it all apart and refitted again but that didn't help.
    If anyone has any suggestions I'd be very appreciative. "Leave it to the experts next time"??? Yep, I gave myself that suggestion already!
    Cheers, Matty.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Always disconnect the negative battery terminal when working on electrics. Check your fuses and the blower relay. To get rid of the airbag warning light you will need to have it reset by Holden or someone with the right equipment.
    MY RIDE
    vs S3 ute
    Nov 2009
    toowoomba QLD
    could always pull the bulb out from the airbag light...
    it's not like they're useful anyway... LOL
    Oct 2007
    Hi all,
    accentstencil - thanks for the advice. After replacing the 15A fuse in Slot 1, it seemed to have fixed the LCD display as well as the fan speed issue, which I wasn't expecting. Still need to get Holden or maybe another auto lecco to reset the airbag status...
    The High Beam indicator bulb (the whole reason I took the dash cluster out...) didn't look blown, but I replaced it anyway. Still doesn't work though... Does anyone have any idea as to whether it is likely to be the actual bulb holder connection on the underside of the dash cluster, or maybe wiring from the indicator/high beam arm? I swapped the globe holders around too with one I knew worked, so it isn't the original globe holder...
    Cheers, Matt.
    VSII V6 Berlina Wagon, Auto
    VY SS Crewman Ute, Auto
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    If you're game, rip the gauge cluster out again and have a look at the PCB tracks. One could be broken. Failing that, get the globe holder and globe currently in position and test with a 9v battery or something. If that's all cool, snoop around for the wire that's supposed to have current running through it when you flick to high beam.. If it DOES, then it's somewhere in the cluster. Look at the PCB tracks again. If it doesn't, then you have a job on your hands... Someone gets to go wire tracing!
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    Oct 2007
    Hi Fonzie,
    Thanks for the suggestion. I did notice that the cluster was very difficult to get out when I removed it. Having removed the cluster from my old VP I assumed the VS to have the same PCB board (or PCB sheet, whatever....) that can easily be damaged. I was very careful with it but I did notice that there were some scratches on the under side. Nothing looked too dramatic, but what would I know...
    If it is the PCB sheet, does anyone know if these are available from Holden separately from the cluster?
    Cheers, Matt.
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    I'd suggest you test the high beam indicator's track rather than straight away assume it's the problem. Use a battery and a light, test each length of track. When you find one that doesn't work, narrow the tested length down until you find the break, remember that you may not be able to actually see it. If it's a small break, I'd suggest getting some conductive paint, scraping back the green coating, and repairing it. If it's a big break, there are quite a few different versions of that PCB, for a replacement you'll have to get the correct numbers and snoop around the wreckers for a while. I doubt it'd cost you much, but getting one in good condition would be a mongrel...
    For a new PCB, you could also try getting onto Shane (88GreenVN). I managed to bugger a few tracks on my PCB a little while back, and he had a spare lying around that I bought off him.
    Fonzie
    VS Executive S1 Station Wagon
    Sep 2007
    Quote Originally Posted by VP-Matty View Post
    Hi Fonzie,
    Cheers, Matt.
    When you're removing the cluster, set the adjustable steering to the lowest and also most extended position. This helps the cluster go in and out really easily or you might find another adjustment that works.
    It shouldn't be that hard... Mainly because any fidgeting might damage the PCB on the back. You've got to be pretty careful but it shouldn't be difficult.
    I upgraded my Executive from Level 2 dash (Just RPM and Speedo) to the full Level 3 dash that you have in your car. It wasn't all that difficult to convert either.
    When I rung holden to get a price on these, they were $400 just for the LCD's that go into the cluster... and they AREN'T available either (thank god at those prices).
    Best to check e-bay and just get another cluster. Spend 2 - 3 weeks waiting for the right one to come cheaply for you.
    Even if you've fixed yours, I recommend getting another as a spare anyway. Never know when you might need a replacement.
    checkout myVS S1 Wagon here!
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Please Help - VT Instrument Cluster
    By Miss-E in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2006, 01:46 AM
  3. instrument cluster
    By donwb in forum General
    Last Post: 06-05-2006, 02:28 PM
  4. Instrument Cluster
    By diggler85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 05:37 PM
  5. instrument issues
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2005, 02:20 PM
