Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Vr V6 Running on 5 Cylinders
    1994 VR Wagon and 1997 VS Calais International
    Jan 2007
    Default Vr V6 Running on 5 Cylinders
    My VR lost a Cylinder on the weekend
    Well its still there but not firing
    I put new plugs and leads in her today and still the same
    I put the timing light on each lead and No. 2 is dead
    So does this mean No2-5 Coil is stuffed
    Or could it be a bad connection in the coil pack
    All help appreciated
    Stop looking for the Potholes and sit back and Enjoy the Ride
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Jan 2007
    Quote Originally Posted by hako View Post
    Gap the plug down to 1.0mm and see if it fires.
    Hi Mate
    Just wondering what your background is
    Are you a mechanic
    Let me know
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm not a mechanic, just a car owner who has always fixed his own car(s) over the last 50 years and also fix my kids cars as well. When I give advice it's to the best of my knowledge and given in good faith. I do have a technical background and prefer to have dirty rather than clean hands.
    In the case of your cylinder not firing I suggested gapping the plug down to 1.0mm instead of the recommended 1.5mm. This may enable the plug to fire at a lower voltage if you have a weak coil or the plug lead to that cylinder having a high resistance. To my way of thinking that would be the first test I would do - plus it is simple and costs nothing.
    Next test would be to measure the compression on that cylinder which is only possible if you have a compression gauge, however in the absence of a comp gauge you can roughly figure out whether the compression is down on one cylinder by first pulling the fuel pump fuse then running the engine till it stalls then crank the motor over - it should turn over smoothly if all 6 cylinders have similar compression ratios, but if one cylinder has lost compression the motor will stumble and not turn over smoothly. Do not run the starter motor for more than 5 seconds - wait a few minutes for it to cool down.
    One big problem with giving advice or help on any forum including JC is that you never know the ability or inclination or whatever of the person giving or receiving that advice - which is why this is a long post to try and explain from my perspective! Good Luck.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by Sara Pax View Post
    Hi Mate
    Are you a mechanic
    Let me know
    I will not chime in here because obviously you are wary of harming your car, but doing what he said cannot harm anything so its worth a try.
    Jan 2007
    Thats OK mate
    So whats your Tech Background
    I am not a Mechanic either
    But have a dirty hands tech background too
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Thats OK mate
    please no offence, but is this a job interview?
    what the fella said is correct, but will be a short term fix, if the coil is breaking down
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jan 2007
    Quote Originally Posted by andyman View Post
    Sure mate
    Do you want to apply
    Are you a Mechanic
    98' VS V6 UTE
    Nov 2009
    Sure mate
    Are you a Mechanic
    yeah your cool do you want help from these guys or not........
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Sure mate
    Are you a Mechanic
    i sure am but i wouldnt work with/for you,
    Jan 2007
    Why not
    Maybe i know more than you
    Considering your a Mower Mechanic
    VS Executive II v6 3.8L
    Oct 2009
    Thumbs down tool
    stop being a tool, go pull the stupid plug out and give it a go or if you think you know better go to a junk yard and get a new coil. If my car was a screwed as yours sounds like i wouldn't be wasting time running my mouth, if you don't want help don't post.
    98' VS V6 UTE
    Nov 2009
    Thumbs down tool
    Quote Originally Posted by waffles666 View Post
    x 2 ..........
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    pour some sugar in the fuel tank...guaranteed to bring the other 5 cyls inline with the crook one...
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Why not
    i am, but im also a light vehicle, heavy vehicle, heavy plant and earthmoving equiment,
    in saying that though, if you knew more, you would have had it fixed without creating a thread on a website
    i also wouldnt do jobs for you cause you seem like a nut case that expects more than whats realistic
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thats OK mate
    My background has simply been chasing balloons - weather balloons. From the time I left school till I retired at least twice a shift I would release and track a weather balloon either with a theodolite, windfinding radar or GPS....sometimes with a radiosonde attached. We even made our own hydrogen for the balloons using ferrosilicon and caustic soda. My job description was Technical Officer and apart from playing with balloons you also had a raft of other instrumentation which you monitored and reported on 24 hours a day. You generally worked on your own, at one of many remote weather stations like Charleville, Mt Isa, Giles etc and if something breaks, you fixed or replaced it. We used slide rules initially and graduated to computers well before the general public became aware of them. I find it quite amazing that just on 50 years ago in 1959 when I joined the Bureau we were receiving satellite pictures for the TIROS weather satellite.....ain't nothing new!
    Anyways, I always loved playing with anything mechanical and whilst half my time would be spent on administrative duties I would always grab the chance to pull something apart.
    So to used that old saying, I know a little about a lot and a lot about little. Win some, lose some.
    Apart from the paid work side of life I've done most things from rewiring a house to demolishing one and similar with cars, trucks,trailers and wheelbarrows. I tell my grandkids that I can fix anything except a broken heart....they understand that.
    Really I think a lot of JC members have similar inclinations....good fun and as a bonus you get dirty fingernails. Good Luck.
  17. #17
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Shit no, I'll keep my tongue in my head.
    Reminds me of a thread a long time ago, that someone is now using as a sig.
    "You come on here and ask me for help, then tell me im wrong? here's a big @#$% off to you! "
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  18. #18
    Oct 2009
    Default hako
    By the way you should listen to hako he's a good bloke, always giving helpful advice on almost all the threads i have read if only there were more people like him.
  19. #19
    Jan 2007
    Gee a lot of you have a great amount of "Shit on the Liver"
    All i asked was if he was a Mechanic
    Then all this bullshit started
    WOW
    What i am thinking now is that any of you lot that are mechanics would be better off collecting trolleys at K Mart
    Thats where your Expertise is
    You probably couldn't diagnose an empty fuel tank
    And to Mr Hako sorry if i offended with the question
    Sounds like you had an interesting job from what you have told
  20. #20
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You certainly did not offend me - so no problems. My kids are often remarking to me that people of my era saw the best days but I dunno.
    Anyway, this forum is for friendly car talk so is the VS still running on 5 pots?
  21. #21
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    WOW
    Here's an idea, go to a mechanic if you want to talk to a mechanic. Dont be all up in peoples faces asking what their qualifications are when people try to help, Im surprised hako is even talking to you at all.
    You come on a commodore forum for enthusiasts and expect to be talking to a mechanic each time? Sad fact is, someone pushing a trolley at K-mart would still know more about cars than you. Probably have a higher IQ too. Jog the fu*k on.
    The hall of fame:
    ಠ_ಠ
  22. #22
    VSV6's Avatar
    VSV6 is offline I wanna hear that boom
    1996 VS Commodore
    Jun 2009
    Warragul
    Anyone with some basic common sense would know that making a smaller gap in a spark plug is not going to damage anything. F*ck sake your making less voltage. The guys here are trying to help you. And they always seem to give me helpful ideas and advice when I ask for it.. Keywords being there "Idea's & advice". Take what's given.. Being a rude c*nt won't look so good when you ask for advice next time.
    And yes, I agree with hako, smaller gap will decrease the voltage which will give you a "clearer" indication if it is the coil.
    My background: Electrical Engineering, 2nd Year Uni student. Is that good enough for you?
  23. #23
    Jan 2007
    **** me dead you wankers cant stop
    The car is fixed
    Faulty coil
    And while i was there i whacked in some new plugs and leads as they havent been replaced for yonks
    the car was fixed while all you nasty tossers where typing ya crap
    Pull the corncob out ya arses
  24. #24
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Good to see it was just the coil and not a bad valve or worse. Just for info, if the coil was the problem on number 2, was it OK on number 5? Reason I ask is I'm a bit curious as to whether the coil actually has 2 sets of individual primary and secondary coils inside the one coil.
  25. #25
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Thats OK mate
    you come in a forum, and ask for advice on why ur car isnt running its best, you get ur answers, then you critisise if the person giving advice is from mechanical background ?
    Quote Originally Posted by MR T
    You Fool
  1. vs running on 4 cylinders
    By zx7rtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 05:59 AM
  2. VN S1 only running on 4 cylinders
    By norman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2009, 12:55 PM
  3. Running on 5 cylinders.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 07:03 PM
  4. Not running all Cylinders
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 07:59 PM
  5. dropped two cylinders!!!!
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2006, 11:00 AM
