Results 1 to 4 of 4
Thread: stripped rear shock thread.....help!
    VS SS MANUAL
    Aug 2009
    BRISBANE
    Question stripped rear shock thread.....help!
    after installing a set of rear ultra lows today i noticed after taking the passenger side shock off the bottom thread that it was mostly stripped, after having a good look at it i couldnt see any easy way of replaceing it.
    does anyone know how i would go about changing this thread over?, does it have to be cut off and re-welded?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You could probably recut the thread using the right sized die....or like you say, cut the damaged thread off and reweld a stub with the correct thread on it. I'd guess that the nut/washer only prevents the shock from moving sideways so there should not be a great pressure on it although you wouldn't want it coming off at the wrong moment!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by thesanchez View Post
    I would say unfortunatly yes.
    Reaper
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You could try using a bolt and nut. The thread goes all the way through doesn't it?
    Visit my Facebook page
  1. Need new Rear-End Shock Absorbers
    By crazybiker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2009, 04:38 PM
  2. leaky rear shock absorber
    By paynie in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-05-2009, 09:31 PM
  3. Rear shock issues
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2008, 10:40 PM
  4. Rear shock air valve
    By sykdup in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-10-2007, 02:32 PM
  5. Rear Shock Absorbers
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 01:55 PM
