Results 1 to 5 of 5
Thread: PRND321 Fascia
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Default PRND321 Fascia
    Hey,
    I just finished reading the VR-VS interior topic and have a question about the auto transmission.
    I installed a BLUE LED in place or the original which blew, and the current PRND321 cover has a green backing on it which I am guessing works as the filter?.
    My question is do I remove that so it shines through even brighter? Because at the moment you can see it well but it looks nothing like this:
    Or do I buy a new fascia that doesn't have backing on it?
    If you want pics of my fascia to see the backing on it just let me know
    Nick
    Check It Out
    My 93' VR Executive
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    No mate, thats an example of HOW it should look like, mine is a lot duller then that and I think it has something to do with the green painted on the back of the fascia because I think it is working as a filter type thing.
    Know what I mean mate?
    Check It Out
    My 93' VR Executive
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Yes i do. The back of it is covered in a Gel-coat. You need to pick this off. Then under it is the green. You have to be really carefull doing this --> Get some very fine wet rub sandpaper and rub the green off. Do it very lightly, as if you sand through the green layer, you will start to sand off the white and the black layers, which will end in a crummy finish.
    I did mine different to yours. I made a custom 8 LED strip running down the hole fascia.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Hey again mate!!
    Yours looks really nice man, can you PM me your MSN address so I can talk to you on there about it? That looks very effective I might consider doing that.
    Check It Out
    My 93' VR Executive
  1. vt/vx fascia fit?
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2009, 11:53 AM
  2. Fitting PRND321 Lights
    By fitz_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2008, 10:29 PM
  3. Dash PRND321 Lights, VT Acclaim
    By Riggy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2007, 06:23 AM
  4. PRND321 indicator removal
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2006, 08:38 AM
  5. changing fascia
    By chirpies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2005, 11:27 PM
