Results 1 to 9 of 9
Thread: o2 sensors do they just die or get sick ?
    vx berlina
    Aug 2005
    gladstone
    Exclamation o2 sensors do they just die or get sick ?
    so guys can any1 out there please tell me if an o2 sensor in a vs v6 can start sending wrong signals to the computer [more fuel consumption] or do they just die and u use a shit load of fuel all of a sudden . my car runs good i think it uses a bit to much fuel .[but i always think that] but the o2 sensors are original at 250 ooo km im just wondering if its worth replacing them or just leave em alone for now ? cheers muz
    '04 VY2 SV8
    Oct 2009
    yeh would send wrong oygen signals and wont burn at the rite mix which means you would use more fuel,will still run if they die completely but will idle ruffer and use a lot more fuel,engine light should come on if there totaly stuffed,they should be changed every 100,000 klms..
    you will notice a diference if you change them i did when i replaced mine.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    They dont normally just die, they slowly get more and more ineffective as they clog up with carbon and other shit from the exhaust. If you suspect you have factory o2 sensors on 250,000kms, change them immediately.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I changed mine at 200,000 klms and found my around town economy increased only slightly whilst my highway cruising improved by at least 20%. At a cost of $110 for the pair they are worth it in my opinion if you are planning on keeping the car for a year or so....otherwise you could be spending money for someone else's benefit.
    vx berlina
    Aug 2005
    gladstone
    ok guys thanks for the advice one other thing on ebay the have vs o2 sensors for sale but some are 4 wire and some are 2 .mines a 97 vs so it should be 4 wires apparently but can any1 confirm this at all ? cheers again guys
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by muzza View Post
    I would say 4, but only way ur gonna confirm 100% if its 4 wire or not, is to check the pigtail connector where your existing sensors plug in. does it have 4 wires going into it or two?
    The hall of fame:
    ಠ_ಠ
    '04 VY2 SV8
    Oct 2009
    im pretty sure the 95 model vs is 2 wire,and 97 model is the 4 wire,if you wanna know for sure jack it up and see how many wires run from it,unless you can see it from the engine bay then even better :-)
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mine is 97 series 2 and had the 4 wire (2 sensors)....and mine were from Ebay. You will find the plug is 4 wire...holdencple is correct. When you change them do it when the exhaust is still hot as it makes them easier to unscrew.
    VR V6 Ute Manual
    Dec 2005
    i got mine replaced this year. it stopped the random engine light from going off. i also found the engine to be running much better and smoother. and much better economy.
  1. Sick, sick dirty bastards
    By DannyboyDS in forum The Pub
    Last Post: 02-03-2009, 07:50 PM
  2. My VY is sick
    By HoldrodeoLT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-09-2008, 10:35 AM
  3. Sick VT Help!!
    By tommythe1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2006, 07:14 PM
  4. How sick does this look
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2005, 07:24 PM
