Results 1 to 11 of 11
Thread: Ecotec into VR Rules and regs in SA
    vr Commodore
    Aug 2006
    Default Ecotec into VR Rules and regs in SA
    The engine in my VR had siezed so was thinking of replacing it with an ecotec engine. If i do this would i require an engineering certificate or mod plate? I am in SA.
    Never be afraid to try new things; remember amateurs build the ark while professionals build the Titanic.
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Just fill in a change of engine form and they may call you in to have a look to make sure stock computer, manifold, etc. is in place. I asked about a Super 6 conversion into mine a while ago and they said it would be no problem just fill out and send in a change of engine form and providing all pollution gear, ecu and other stuff was installed correctly (ie. stock) it would be no worries. More than likely they won't call you in but it may happen, just a random thing they do apparently.
    vr Commodore
    Aug 2006
    Quote Originally Posted by NickVR View Post
    What do you mean when you say stock. Are you refering to stock VR or VS parts. I was thinking of doing on Ecotec conversion from a VS thus would be using a VS ECU, engine harness, engine, BCM and would be running twin oxygen sensors as on the VS.
    Mar 2009
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by westbad View Post
    if you install everything of the vs you wont have any issues
    Exactly right. When I say stock, I mean as it came from the factory in the car it come out in. No lumpy cams, aftermarket ecu's (require an emissions test otherwise) all that sort of stuff.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Just buy a VS?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    vr Commodore
    Aug 2006
    Quote Originally Posted by HamaTime View Post
    Just buy a VS?
    Well, i would not even consider upgrading to an ecotec engine if my VR was running. The engine siezed so it needs replacing and it is not much more work fitting a ecotec engine rather than replacing the old engine. Also i know of a recently fully reconditioned ecotec engine, cheap.
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    Hey mate, sorry for this but im trying the same conversion. as my engine has done the same thing. i was just wondering if you had any issues with your exhaust. does the vr exhaust fit straight to the vs engine or do i need a whole new exhaust system please let me know thanks mate.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    do you know this for fact or are you just going on the fact that the engine is different.. please let me know
    Mar 2009
    you should be able to use the exhaust from cat back
  1. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  2. Anyone know the plumbing regs.
    By VrWagz1 in forum The Pub
    Last Post: 07-09-2009, 01:09 PM
  3. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  4. f.s: electric regs
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 08-08-2006, 12:11 PM
  5. Fuel Regs.
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2005, 04:24 PM
