Results 1 to 3 of 3
Thread: performance tweaking and tuning tips??
    mantavs96 is offline MANTA MAN
    VS manta HSV
    Dec 2009
    perth
    Default performance tweaking and tuning tips??
    i have a hsv manta and want to no if by playing with the ildling or the timing would adjust performance or power to my car it has a stage 1 chip and extractors but otherwise its a pretty standard engine ... any suggestions other than a dyno tune
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    what do you mean by stage one chip? has it been modified? Playing with the idling is going to get you nothing in the way of performance, but changing the timing will. If you've modified the chip though, I wouldnt change the timing unless you know what you're doing.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS manta HSV
    Dec 2009
    perth
    yea its a modified chip
  1. tuning a vy acclaim for performance?
    By josh.meaden in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2009, 05:02 PM
  2. Some tips for VN calais performance
    By bad_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2009, 03:11 PM
  3. Is it possible to do any ECU tweaking?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 01:31 PM
  4. tweaking
    By silver_bullet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 01:14 PM
