Results 1 to 21 of 21
Thread: sMoKy
    Commodore vs Wagon
    Jul 2009
    Default sMoKy
    Hi Guys
    Say if everytime you take off and you have blue smoke comes out of the exhaust
    will these reduce it??? Calibre Stop Smoke - 300ml - Supercheap Auto
    And do you just put it in the engine were you put oil in??
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Stuff like that will just temporarily fix it.(if your lucky).It probably needs new rings or valve seals,or maybe a full reco engine.How many k's has the car done?Id do a compression check/test to get an idea of the condition of the engine.
    Commodore vs Wagon
    Jul 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    Its not an extremely high milage,I've seen VS's with double that just getting their second engine.Maybe it hasnt been looked after to well.Id compression test it.The main two things that make a motor blow blue smoke is either worn valve seals/guides, or worn pistons/piston rings.The compression test will tell all.It should push out over 689kpa(100 psi)(this is the minimum cylinder pressure).The lowest reading on any cylinder should not be less than 70% of the highest reading on any cylinder.
    Commodore vs Wagon
    Jul 2009
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by Ryaz11 View Post
    so what happends if its any lower then that??
    new motor?
    u can get a new motor or u can just get urs rebuilt with new cylinder rings. prolly better to get a rebuilt than a second hand motor cause then urs is like brand new again
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    vs commodore
    Oct 2009
    Tamworth NSW
    When I bought my car it had a complete reco'ed engine fitted from redlands in Brisbane,the receipt was in the glovebox,it cost around $2500.If you can do some work disassemble/reassemble some things yourself,it should work out cheaper,someone else here might have a better idea on the cost of doing some stuff yourself.It might not even come to this yet.
    Commodore vs Wagon
    Jul 2009
    yes its quite annoying it only happends now and then always in the morning a whole heap of smoke then its ok for the rest of the day.
    the mechanic i went to said he didnt no what it is he just put thicker oil in it
    vs commodore
    Oct 2009
    Tamworth NSW
    Is the smoke definitely blue,and not blackish sooty looking?Sometimes a sensor can be bad and makes the engine management feed to much fuel (to rich)when its cold,which will make it blow blackish smoke.Try checking codes.Checking error codes VR/VS (Revised).If you dont know how ,look at this.
    Commodore vs Wagon
    Jul 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    If its blue(oil) then rebuilding/reconditioning is the only answer.Thicker oil might work for a while.
    Commodore vs Wagon
    Jul 2009
    VR Commodore
    Apr 2009
    So it smokes a bit in the morning and fine the rest of the day? Sounds to me like your rings are probably ok but just your valve stem seals are shot. That's an easy fix. All the mechanic needs to do is hold the valves in each cylinder with air and take the collets, springs and dampers off and then replace the seals one by one. You won't need to take the heads off this way.
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Blue smoke can also mean a blown/warped head.
    But it doesnt sound like he has it..
    So i'd say invest in feeler guages, straight edge, torque wrench, socket sets, ring spanners, ring compressor and a gregory's manual and re-build the engine.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it only happens when taking off and not normal running at 60kph then it might just be the valve stem seals. The best way to tell if it is worn rings is to hold the revs at about 2500rpm (engine warm) - if it starts and continues blowing blue smoke as you hold these revs then it's rings for sure. There are other things that can cause smoke like an overfilled crankcase etc which will also eventually stuff the catalytic converter up. PCV might be blocked as well.
    If it is the rings and you don't want to spend big dollars you can just fill the engine with the heaviest grade of oil (40W70?) and also add a can of that "stop smoke" as well if it's smoking bad. All this stuff does is make the oil thicker which ain't the best for efficiency but it sure cuts down the smokescreen. Coppers will defect you if it smoke for more than 10 seconds I think. My old FJ was so bad I carried spare plugs with me to change the oil soaked ones every few miles.
  16. #16
    VR Commodore
    Apr 2009
    Oh, and valve stem seals commonly go after many years on all cars. My brothers Commodore did the same thing. Started up, blue smoke, drove off, poured out blue smoke then after 1km, fine.
  17. #17
    Commodore vs Wagon
    Jul 2009
    Crazy-vr thats exactly like mine 1-2km fine
    thanks for all your help guys its a bugger of a thing
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    Another test you can try is letting it idle(once its up to running temp)for about 5 min,then open the throttle up to about 3000 RPM.If it blows a heap of smoke after sitting there idling,its a sure sign of it being the valve seals.
  19. #19
    Commodore vs Wagon
    Jul 2009
    so im guesssing its better that the valve seals are gone then the piston rings? how much for new valve seals?
  20. #20
    vs commodore
    Oct 2009
    Tamworth NSW
    What crazy.vr said about holding the valves shut with compressed air is the cheapest way of doing the valve seals,otherwise the heads have to come off.Valve seals are probably around $20.for a set.Thats only a guess though.But they shouldnt be much dearer than that.(bought some years ago for around $10.)
  21. #21
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you haven't got compressed air you can feed string/thin rope into the plug hole then rotate the engine to force the string up against the valves......or use a bent length of 1/4" rod thru the plug hole to hold the valve up. More than one way to skin a cat.
  1. vs smoky tail lights
    By Re5pect in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2007, 06:56 PM
