Results 1 to 3 of 3
Thread: AC Fan Speed
    VS Series II
    Nov 2007
    Newcastle
    Default AC Fan Speed
    Hey all,
    Was just driving this morning, and it was a hot one, so i put the AC on. My usual speed is 2 on the dial, as my system needs a regass, so its colder when the fans lower. anyways, after driving for a little while on 2, and not feeling anything, I put it on 3 and a big wave of cool air came out and it continued to blow. Tried it on 4, and it still came out. Went back to 2 - nothing, then lastly 1. and nothing on that either.
    When I pulled up i put the car on acc. and went thru all speeds. My fan only works on 3 & 4.
    What should I be looking for? Fan motor? Fuse? Switch?
    While I've got the thread - What's the clicking around the glovebox area occasionally when the air con is on?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The speed problem is related the the fan speed resistor bank - there is a "how-to" in that section on how to replace it (simple). The clicking you are hearing is probably the A/C thermostat turning the compressor on/off - it measures the air coming thru the evaporator and turn the compressor off at a certain temp, otherwise the evaporator will ice up.
    Here is the link: VR / VS - Interior Fan Faulty
    VS Series II
    Nov 2007
    Newcastle
    thanks mate. very helpful. i searched the site, but didnt know exactly what i was looking for.
    cheers
LinkBacks (?)
  1. 08-02-2010, 08:30 AM
  1. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 06:39 PM
  2. 4 Speed Auto VS 6 Speed Manual?
    By Wicked_D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 02:09 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
