Results 1 to 7 of 7
Thread: irs conversion
    vr
    Jun 2009
    Default irs conversion
    ive just been searching the forum and cannot find anything on this topic..can a irs rear end be put into a non irs vr sedan. im just wondering as i can get a complete irs assembly including the support frame for free off a mate. does the support assy just bolt up to where the orig upper and lower trailing arms bolt to? has anyone done an irs conversion? any info would be great, thanks.
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Theres no way its just a bolt in job. Will require getting an engineer to weld the whole rear of an IRS car onto it, because the floor pan is a completely different shape.
    Might aswell forget about that idea, and just buy an IRS car.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    vr
    Jun 2009
    thanks stealthy.yeah im able to do the welding no probs, but understand there is just way too much work involved with that. i thought holden might have been kind enough to use the same floor pan, just different components depending on spec level.. ah well you win some, you loose some.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Stick with the solid rearend - the IRS has no real advantage and a lot more things to go wrong plus camber wear. The way it has been done is using a "cut and shut"....but just not worth it.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by hako View Post
    The only advantage is better handling. Camber wear isn't a problem with a camber kit....
    cheers sexy
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Go buy two IRS cars for the price it will cost for the conversion.
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    It's a fair question but I think it is a pointless thing to do because it will cost thousands and will require more than just a floor pan/IRS cradle conversion and a engineers certificate to work. As said before you will need to get a camber correction kit which is an added cost and plus it's an old car so I wouldn't even both throwing the money at it.
    Stick with a live axle, true it doesn't handle as good but it doesn't bog down like IRS does. You'll save heaps of money, just go and buy a factory IRS car.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. vu to vy conversion
    By Conn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2009, 04:45 PM
  3. L67 conversion
    By vs-6 in forum V6 Development And Modification
    Last Post: 03-03-2008, 05:24 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
