I dont know if this has been covered (i could only find info on VN and thats not of much help as there greatly different wiring).
Anyway im looking to install a factory cruise control into my VR ute (Non ecotec), i know i need the stalk, module/box and the switch for the brake pedel. But is there anything else thats needed and will it be a simple plug and play or is there wiring and work that needs to be done to install it ?
Also if anyone has any pictures, info or illustrations to help with the install would be appreciated.
If you are lucky you will have the wires already installed but I have a feeling the VR utes missed out which means you may need to strip the wiring from a sedan. However, check this thread as it should answer most of your questions. How do I install genuine cruise control on a vs executive?
You will also need a clutch switch if it's a manual plus a relay which goes under the steering wheel.
