Results 1 to 8 of 8
Thread: spark plugs
    Commodore vs Wagon
    Jul 2009
    Default spark plugs
    hey guys
    i want to change my spark plugs is there a how to section on here??
    is it just pulling the spark plug out? whats this about leaving a gap??
    what tools do i need?
    its a bugger to get behind the alternator to do the drivers side
    Thanks Guys
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    It's all really common sense.
    You need a spark plug socket to suit, a ratchet to suit the socket.
    The plugs should be gapped to the right amount when bought.
    When changing the plugs, change them one at a time by pulling one lead off, change plug, replace lead, move onto next one.
    The spark plug has a thread on it so you have to screw it out with the ratchet and socket.
    When tightening them, dont over do it, just do it till there firm. Or if you have a torque wrench set it to 45Nm I think it is? and do it up till it clicks.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Commodore vs Wagon
    Jul 2009
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    If you plan on working on your car a fair bit, I suggest you get a Gregory's manual, which is very helpful and pays for itself in the long run. They are about 45 - 50 dollars.
    My Commy
    Discuss.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    One important thing to remember is to pull the lead off by pulling and twisting the plug connector....don't pull on the lead as you will break the lead internally and then have to buy a new set.
    And as Wombles says, a Gregorys manual comes in awful handy.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Just to save your hands for loosing to much bark i got a pair of supacheap gloves and found them very handy saved a bit of skin and got a better grip on the lead boot on the spark plug some can be tight.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VS_Pete_1 View Post
    Spot on Peter, I stupidly did mine whilst the exhaust manifold was still VERY hot....I could smell pork frying.
    VS_Pete_1's Avatar
    Dec 2007
    Funny thing about it is I had them for 2days and had a miss the sparkplug lead was loose came is handy I tell you.lol
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. spark plugs
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2010, 08:20 PM
  3. Spark Plugs.
    By spd_dmn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-12-2005, 10:46 AM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. spark plugs
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2005, 08:52 AM
