Results 1 to 25 of 25
Thread: filling in the side seams on my VS ?
    1996 VS, S, 3.8 Ute
    Sep 2008
    Default filling in the side seams on my VS ?
    has anyone filled in the side seams on a VS? I'm sure I've read in here some time ago but just can't find any info now.
    I'm gonna be painting my VS ute soon and want the sides to be flat, so was thinking maybe I'll fill them in with bog or fiberglass?
    Does anyone have any pics of a VS ute or even sedan/wagon that's had this done?
    cheers for all and any info
    Mar 2009
    Hi, im a qualified spraypainter/panel beater so thought i would give you a few tips ;-) If you fill them with regular bog it will crack after time, ive smoothed heaps of cars in the past and i always use fiber reinforced bodyfiller aka fiberglass filler for the 1st skim to build up the recess to the same level as the rest of the panel then for the final skim use fine filler or regular bog. The only issue you will have is where the door meets the front guard once smoothed the very front edge of the door where the recess was will catch on the bit you have smoothed on the guard. So the very end part of the recess on the door and start of the recess on the guard needs to angle in slightly to clear each other ;-)
    Unfortunately i dont have any photos of the ones i have done in the past but hope this helps.
    1996 VS, S, 3.8 Ute
    Sep 2008
    good info cheers mate, so you do the front bumper too or just the sides? I think I'm gonna leave the tailgate as stock too because under the seam is almost an inch raised above the rest of the panel
    keep the ideas coming guys
    VL EXEC
    Aug 2008
    perth wa
    id do it the same way door handles are shaved weld a bit of steel in there, smooth out welds, lay bog over joins, sand, metal condition it and paint away
    like previously said bog is just gonna crack and flake and turn to shit over time think of the gap your filling and the sealing properties of the product in use and honestly welding a bit of metal in will be 10 times easier and cheaper now doubt
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    Mar 2009
    They can be welded up to but it is very tricky to get that right, you have to be carefull not to heat the panel to much or they will warp and then you will be in trouble lol.
    Plus all your welds would have to be air tight, any gaps in the weld would cause the bog on top to bubble eventually.
    VL EXEC
    Aug 2008
    perth wa
    thats why u just stitch weld it into place then bog up the gaps left in place
    after using litre after litre of body bog and fibreglass based bog i know what id rather be doing
    Mar 2009
    1996 VS, S, 3.8 Ute
    Sep 2008
    nah mate welding is not an option
    looks like fiberglass filler for the big gap is the go
    c'mon guys I'd love to see some pics if anyone has any
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by R3D_D3AD View Post
    I just gotta say it must take balls to attempt something like this that can go so badly wrong especially on a perfectly good car. Good luck.
    1996 VS, S, 3.8 Ute
    Sep 2008
    car has panel damage so it's getting a bit of bog and paint no matter what, I got nothing to lose
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Quote Originally Posted by jokerflingo View Post
    why? I did it, it's not perfect but worst case scenario, rub it back, do it again.
    Aug 2008
    I didn't know that it had panel damage and needed the bog already. Still takes ball though.
    Mar 2009
    its pretty easy to do.. if you have the skill to rub filler down well to get the correct shape you will have no problems.
    VS Berlina
    Feb 2007
    always pays to get whatever help you can too, panel damage is a bugger unless you have someone who knows at least a little about using the tools correctly.
  15. #15
    1996 VS, S, 3.8 Ute
    Sep 2008
    pic, pics, PICS!!!
    My old man's doing the work I know nothing about repairing panels but I'll hopefully learn a thing or to from him. Basically the whole 1/4 panel got crumpled up and he refuses to even consider the idea of welding in a replacement, so bashing it out and filling it is the go, only thing is I know it's going to be 100% impossible for him to shape the seams back into it, so that's why I'm here getting your opinions
    If someone posts some pics of a VS or VR ute with the sides filled in I'll post pics of just how extreme the damage is
  16. #16
    Mar 2009
    post some pics up for the damage mate, ive welded in replacement quarter panels on utes before and its a hell of a lot easier to weld a new panel on than it can be to repair some major panel damage.
  17. #17
    VR Series II Equipe smokey 3.8 + clunky Auto
    Jul 2009
    I'm also a qualified painter and have done a few of these jobs and agree with everthing that westbad has said, going by what he's said he has definately done it before as he said. The most effective looking car I've done it to was my old VK, I did the doors, the bumpers...etc, then painted it a nice met. blue with colour coded bumpers plus really dark tint and chrome mags dropped on it's guts...looked nice...wish i still had it now!
    The whole respray only took me a week, a day to strip it down and get doors off and strip the areas needed back to metal, then a day was spent bogging sanding and priming the doors, another day prepping the rest of the car and priming. Another couple of days blocking back and repriming where needed and then a couple of days painting and fitting panels..etc. So if your willing to put in the hard work, you can get a lot done in a short period of time which means less down time on the car and which means you'll be back in car hanging skids in no time! lol
  18. #18
    Mar 2009
    Quote Originally Posted by -=$natch=- View Post
  19. #19
    1996 VS, S, 3.8 Ute
    Sep 2008
    everyone says to cut and weld it, but the old mans being stubborn about it.
    anyone got a rough idea how much a replacement panel would cost? would I buy it new or just get from a wrecker?
  20. #20
    Mar 2009
    new panel would be a whole let better and easier to fit mate, theres no way id be trying to repair that.. will be heaps easier to cut that panel off and weld on a new one. I could have that damaged panel off and new one welded on in a day easy..
  21. #21
    1996 VS, S, 3.8 Ute
    Sep 2008
    so where would I source a panel from? If it doesn't cost way too much I'll try n convince the old man
  22. #22
    Mar 2009
    new panel wont be cheap if you can find one.. id be expecting anywhere from $600+ at a guess.
    Where abouts do you live..?? SSS in melbourne may do one
  23. #23
    Mar 2009
    SSS auto parts Pty Ltd
    1952 Hume Highway,
    Campbellfield
    Victoria 3061 Australia
    Tel: 03-9357 8555
  24. #24
    Aug 2008
    I can tell you hear and now you will be much better off getting a new panel as that one is absolutely ****ed, can i ask what caused the damage?
  25. #25
    1996 VS, S, 3.8 Ute
    Sep 2008
    right cheers mate I'll give them a call.
    little sister was driving on a dirt road and lost control, took out about 30meters of chain link fence scraping along the side. I won't be lending my cars n bikes to anyone any time soon hahah
  1. Car stalling after filling up
    By brisbane_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2009, 12:21 PM
  2. Gas over filling
    By VL Berlina 5speed in forum General
    Last Post: 29-08-2008, 02:38 AM
  3. Filling GearBox
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2008, 09:57 PM
  4. Over filling the oil sump
    By Hytes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2008, 01:43 PM
  5. Filling My VS
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 11:17 AM
