Results 1 to 4 of 4
Thread: vs commodore radius rod replacement!!!need help ASAP
    1984 vk commodore
    Nov 2009
    Rockhampton
    Exclamation vs commodore radius rod replacement!!!need help ASAP
    im currently replacing my radius rod bushes, i have went out and got rubber ones!!! stupid mistake..... will i have to get them pressed in????????????????????????????????
    vs commodore
    Oct 2009
    Tamworth NSW
    I think the rubber ones do have to be pressed in,Nolothane brand and similar just push in by hand.They come in two pieces .I just cut around the old rubber ones with a knife to get them out.
    vs v6
    Nov 2009
    an easier way to get them out...if you have it up on a hoist or high enough off the ground use the actual rod.....poke an end in and pull the down rod straight down...ya might even need to go side to side a bit....the rubbers just peel out real easy!! just done mine about 6 weeks ago...used nolothane as brett jjj said... 2 pieces easy
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I did a VERY detailed write up on this some years ago, I have refined the method since writing it so feel free to PM me any questions if you get stuck.
    Here is the link.
    http://forums.justcommodores.com.au/...od-bushes.html
    Hope it helps.
  1. VT-VZ Commodore Radius Rod Bushes
    By Huthy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-02-2012, 07:59 PM
  2. VT Commodore Sway Bar Link Replacement
    By HarryR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2010, 04:13 PM
  3. VS Commodore Clutch Replacement
    By slipery_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2009, 09:22 PM
  4. [VIC] WTB: COMMODORE CAT CONVERTER ASAP in VIC
    By calaiscruzer in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2009, 12:31 PM
  5. for sale vr commodore need to sell asap (sa)
    By tunney in forum Vehicles For Sale
    Last Post: 08-05-2007, 12:17 AM
