Results 1 to 7 of 7
Thread: Vs ss gilmer drive question
    VS SS COMMODORE S2
    Feb 2009
    Kingaroy, QLD
    Default Vs ss gilmer drive question
    Hey Guys, just wondering if its possible to put a Gilmer Drive on my ss if it still has the clutch fan on it and no thermo fans? i have seen heaps of gilmers on cars with thermos but not clutch fans....
    vs ss
    Aug 2009
    reservoir
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    im pretty sure you can, my mate had the gilmer setup on his vs clubby and was running the clutch fan still
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    vs ss
    Aug 2009
    reservoir
    is it hard to keep the air con as well or is it true u stuff up ur alternator with all that tension and does ur car run hotter
    Troy5L's Avatar
    Jun 2005
    the tighter(more noisy) you go the more chance of screwing the water pump as i think it puts more pressure on the pulley.. but from what i have been told your car doesnt run hotter..i think with the aircon you have to but another pulley and pack it out with washers , but im not 2 sure..
    the gilmer drives are just a wank factor, you only need them on high performance n/a or force fed engines, and it stops belts from slipping
    EDIT: plus if you do a search u will find more info on gilmers
    My VS CLUBBY!
    vs ss
    Aug 2009
    reservoir
    so u wouldnt recomend it huh alot of people say its wanky does it atleast sound good
    VN SS
    Oct 2008
    if ya wana retain your air con. machine your standard crank pulley down so its only a single row instead of the standard 3 row. then bolt the gilmer pulley inside that one. i done this on my vn. this way you retain your standard air con with no need to space or modify lines or belts.
    all you will need to do is space your power steer pump and get an different size belt for it.
    theres a thread around that all this is in. if ya cant find it and need more info let me know as i have done it before
  1. Gilmer belt drive
    By AndyVKSSA in forum V8 Development and Modification
    Last Post: 28-12-2010, 05:04 PM
  2. Gilmer drive kits
    By VZHSV in forum V8 Development and Modification
    Last Post: 28-06-2009, 04:28 PM
  3. Gilmer belt drive on Vs ss?
    By andrewownsavp in forum V8 Development and Modification
    Last Post: 14-02-2009, 02:56 PM
  4. WTB Gilmer Drive for 304 ASAP
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 21-05-2008, 05:09 PM
  5. gilmer drive kits
    By crossy0088 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2005, 02:46 AM
