Results 1 to 6 of 6
Thread: vs idling high
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    Default vs idling high
    hey got a 95 vs auto and in neutral and park it idles round 1500 and sumtimes will go up tp 2500rpm. what could be the cuases of this?
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    vs commodore
    Oct 2009
    Tamworth NSW
    Easy Rollins is offline Farking old bastard
    VS Wagon
    Jun 2006
    Sunny Brisbane
    The IAC valve can be come clogged with carbon also.It's located on the side of the throttle body,whip it of and spray with a carby cleaner to lush it out.
    Also check for a air leak on the air intake area,from the air cleaner back to the engine.Spray ny suspect areas with carby cleaner and if a leak the revs will change,as the cleaner burns.
    HTH
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Most times I see this it turns out to be the throttle cable that is sticking - either kinked or frayed. Sometimes a good soaking in WD40 will fix it.
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    I had this same problem years ago in a previous VS. I checked for error codes and I showed up a faulty 'Throttle Position Sensor' which is attached to the throttle body. Replaced that and was fixed.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
  1. s/c L67 idling to high problems?
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2009, 02:50 PM
  2. vr idling high and ruff and missing
    By the dog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2009, 04:41 PM
  3. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  4. Car idling too high after using cruise control
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2006, 03:38 PM
  5. High Idling
    By mal62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2006, 10:54 AM
