i just bought a car off my mate the rear tyre had only 3 studs where the nuts go. i got them fixed and now the same wheel still wobbles and shakes. would there be something major wrong with it ??
Its sounds like its buckled.Take it to a tyre place and get them to check it out on a balancing machine.If its not that,then it could be a stuffed wheel bearing.Jack it up and spin the wheel and listen for any unusual noise,it should be smooth to turn,if it feels rough and not spinning easy then its more that likely the wheel bearing.Its easier to tell what the bearing is like if the brake caliper is removed first.
Brett jjj is spot on I had that as well rim buckled badly
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
can you come do it for me lmao ... ill give it a try or ill get my uncle to come check it out ... i also have a squeek to the car ... like all my other car the wheel squeeks when i drive what would that be ?
Could be a tyre prob.Run your hands around the tyre's tread and feel if there are any bulges-a seperated tread.Check both sides,roll foreward and recheck.
The shaking is a balance problem,be it a tyre,bent rim or bearing flogged right out.
