Results 1 to 7 of 7
Thread: how fast am i going?
    VS ute
    RefleX v1.2 Champion!
    Aug 2009
    Default how fast am i going?
    hey,
    i have bee having problems getting my speedo to work, and when it does the digital, and regular speedo show different speeds, so until i get it properly fixed i thought i would use my tacho to figure out how fast im going,
    its a Series 1 manual v6 vs ute , could somebody please tell me what there taco sits on at popular speed limits (mostly 50 ), and in what gear,
    thanks
    My 5SPD VS UTE!! Now wrecking
    Quote Originally Posted by Grennan View Post
    Aggravated Burnout.... How is that different to a normal burnout, does the guy have a frowny face? Seriously get ****ed.
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    I can see a fault with this solution.
    You will be applying different amounts of throttle at different gradients.
    Also have to take engine/gearbox wear/condition into effect
    Youd be better off trying to wing it by matching the speed of other cars. Or getting a new cluster.
    VS ute
    Aug 2009
    Yer, was going to match the speed to a mates car but haven't had a chance yet...
    I have tried a new cluster, but am still having problems..
    Mar 2009
    you could always use a gps to show your speed, once at a constant speed my tomtom is quite accurate
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    VP Exec
    Jun 2005
    You might try this approach:
    Copy and paste this:
    =(((C6/100*27.777)/(B6*PI()))*3.08*A6*60)
    into a spread sheet.
    C6 is the road speed in km/h
    B6 is the tyre diameter in metres, for a 205/65/15 this is nominally:
    [(205 x 0.65 X 2) + (15 X 25.4)]/1000
    this = 0.6475m
    A6 is the ratio of the gear selected. For T5, V6 this should be:
    First........ 3.25:1
    Second..... 1.99:1
    Third........ 1.29:1
    Fourth...... 1.00:1
    Fifth......... 0.72:1
    An eg. calc. is that 50km/h in fourth gear rpm = 1262.
    Note that there might be some error because the tyre size is nominal.
    If you really wanted to be accurate, you could mark the tyre sidewall and an adjacent point on the ground with chalk, roll the car until the chalk mark on the tyre again touches the ground and mark the ground again. The distance between the chalk marks is the circumference.
    Rolling the car so that the tyre rotates more than once and dividing the distance between the marks by the number of roataions will be more accurate.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by -ToM- View Post
    He drives a manual, so unless he has a slipping clutch thats irrelevant.
    I run 17" 235/45 Tyres, and I think Im just under 1500rpm at 50km/h in 4th.
    PM me an email address and Ill send you a calculator that works out your RPM at speeds etc.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  1. need help fast!!!!!!!!!!
    By VPS2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2009, 08:53 PM
  2. Fast!
    By nathans1987 in forum Jokes/Humour
    Last Post: 29-07-2008, 09:32 AM
  3. how fast is your vl???
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-03-2007, 07:09 PM
  4. How fast?
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2005, 12:27 PM
