Results 1 to 4 of 4
Thread: Anyone got pics of shift solenoids for 4L60E ?
    VS SS
    Mar 2009
    Default Anyone got pics of shift solenoids for 4L60E ?
    Hi all, i want to change the shift solenoids in my dads V6 VR Calais, as i believe they are playing up and dont need a full auto rebuild as mechanic is insisting, does anyone have any pics of these solenoids while still in the trans? I've never attempted this before thats why im asking and my Haynes workshop manual is useless, is there any tricks i should know about before attempting this job? Thanks in advance.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Mate they are easy as to change. All you have to do is, drop the pan and you will see 2 shift solenoids at the back of the value body. They are held in by a clip, undo the clip with a screw driver and unclip the wiring and she will pop out. To put it back in, all you have to do is push it in and push the clip back in. To test the shift solenoids, run 12 volts to one side of the clip and earth the other side. You will hear it clicking, if its good. But before you do all that, check fuse number 18 (i think) and see if it is blown, cuz that will cuz your transmission to play up
    NEVER LATE IN A 355ci
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In addition to what BT1-355 says, check for error codes as bad solenoids normally leave an error code.
    Checking error codes VR/VS (Revised)
    Here is a link to 2.360 images of 4L60E trans parts: 4l60e diagram - Google Images
    vr executive
    Dec 2009
    yeah my engine light came on last night and the error code read 66, 67, 81,82 but i've had mine done twice in the last 6 months so don't know whats going on bt1355 are you sure its no 18 fuse to check cause i'm gonna check it before going back to the mechanic is costing $$$$$$$$$
    it is no 12 just checked fuse blow replaced and every things fine now got all me gears back
  1. Replacing Shift Solenoids in VS auto trans.
    By Portunio in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2009, 07:12 PM
  2. [QLD] FS: Non irs sl king springs and 4l60e shift kit
    By Disturbed_vegeta in forum Parts And Other Items For Sale
    Last Post: 02-03-2009, 07:49 PM
  3. 4l60e, shift kit etc.
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 06:17 PM
  4. B&m Shift Kit For 4l60e
    By BLOW6 in forum Parts And Other Items For Sale
    Last Post: 06-09-2007, 08:40 PM
  5. shift kits, 4l60e
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2006, 06:32 PM
