Results 1 to 11 of 11
Thread: fan belt noise please help!!!!
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    Default fan belt noise please help!!!!
    had a problem for agers with a noise coming from my fan belt area and just wondering if its a common problem with the VS... ive tried changing, constant cleaning of the belt and changed some few bearings but still the noise comes back
    vs commodore
    Oct 2009
    Tamworth NSW
    Could be the water pump.Remove the belt and start the motor,just to make sure its the belt or pulleys doing it.You can(carefully) put a long screwdriver on each pulley centre bolt,or a place where its not spinning and put your ear up to the handle of the screwdriver,you should be able to hear any crook bearings,a buggered bearing will sound noisey and rough compared to a good one.Remember to do the Alternator as well.The bearings go in them every now and then.Just be careful.I dont have to explain what will happen if you get hair,clothing etc caught in the belt or pulleys.You can listen to them the same way with a piece of hose,but it doesnt work as well.
    despo's Avatar
    vs series one
    Jun 2009
    ok i got the new waterpump when i first got the car to get a road worthy on it and ive done the screw driver clean on the belt and in all the grids of the bearings but it only works for a couple of weeks and then slowly its comes back but i have noticed it comes back when i tend to put my foot to the floor but yer running out of options and makes the car sound and look crap which its not
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can you describe the noise - is it groaning ,squeaking, rubbing, or creaking as the type of noise may indicate the source. Also does it go away when the A/C is turned on.
    despo's Avatar
    vs series one
    Jun 2009
    its like a high pitch constant squeaking noise that gets louder as i accelerate not sure with the a/c shall try later on
    vs commodore
    Oct 2009
    Tamworth NSW
    What do you mean you've done the screwdriver clean on the belt ,and in all the grids?Did you listen to the pulleys like I suggested through the screwdriver,This will tell you straight away if its one of the pulley bearings.
    despo's Avatar
    vs series one
    Jun 2009
    umm i put the screw driver in the middle of the bearings the clean them out which seemed to only temp work...... and havnt done the sound thing yet but will try
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,cleaning them wont help much.Its likely to be a stuffed pulley bearing or alternator bearing or balancer .Try what Ive said,it should help point out whats wrong.
    VR Acclaim
    Jun 2009
    despo's Avatar
    vs series one
    Jun 2009
    found out the problem for now..when i bought a new belt it was apparently slightly bigger and i went down to holden and bought a gen belt and so far its quite and i can now hear my sick exhaust..thanks for the idea boys
    rjp
    rjp is offline
    WM Caprice
    May 2009
    The AC belt used to squeak all of the time on my VS S111 V8 as the AC idler pulley was exposed to water every time it rained....
  1. Serpentine belt noise
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2009, 04:01 PM
  2. Belt slip noise in Vz V6
    By OBR1EN in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-05-2008, 11:33 AM
  3. Fan Belt Noise
    By skobs in forum General
    Last Post: 01-09-2007, 11:19 AM
  4. belt noise
    By oldmate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2006, 03:35 PM
  5. noise from belt?
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 01:32 PM
