Results 1 to 5 of 5
Thread: vr calais red 'oil' dash light
    oosty85's Avatar
    oosty85 is offline YSPOOL
    VZ SS 5.7 & VR CALAIS 5L
    Apr 2009
    South West Sydney
    Default vr calais red 'oil' dash light
    hey, just taken my car to work (picton to penrith) on it's first long drive since putting motor back together. I got about 10 mins from work and the oil light on dash came on and stayed on the rest of the way even after i turned car off and on again.
    i let the car sit most of today and checked the oil level and it's right on the "add" line on dipstick.. i thought i put a bit more in it than that but i must not have. (only shitty woolworths brand oil to flush out engine before switching back to penrite this weekend)..
    so i'm just wondering if oil being slightly low can cause the sensor to pick this up or if i have an oil pressure problem?? maybe a blocked oil filter?? (push rods had a bit of shit on them from being open for a couple weeks). there are no abnormal noises or anything but i don't wanna destroy the crankshaft bearings or something by driving it home!!
    just wondering if i should go buy some more oil to make it home, or will this have nothing to do with the dash light coming on..
    cheers, josh.
    oh it's an old 5L not the vz
    Jun 2005
    check with an oil pressure gauge, or you could just have a faulty sensor that needs replacing like mine did
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    leaking oil pressure switch can cause this light too.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VR 5.0 ltr Ute
    Nov 2009
    Beenleigh, QLD
    I got a couple of seals done a little while ago and afterwards the oil light stayed on so i checked the oil pressure sensor thing (ie pulled it off) and it turned out there was a big pocket of air in there, put lil bit more oil in where the sensor belongs and the light went away...
    "I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
    oosty85's Avatar
    Apr 2009
    South West Sydney
    thanks for the ideas, pretty sure the sensor is dodgy as it didn't appear for the whole drive home thankfully.. added more oil though, so see how it goes until weekend.
    could have even been air like you said UBER. cheers!
  1. check Tail Light dash light on
    By egadgetjnr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2009, 11:43 PM
  2. 4 Corners 'Peak Oil'
    By Cheap6 in forum General
    Last Post: 09-08-2006, 12:23 PM
  3. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  4. VP Calais (Dash Light for Tail Lights)
    By fruitytingles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 06:57 PM
  5. need help replacing dash light VT Calais
    By st.anger666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2005, 06:28 PM
