Hey, i just got a set of pacemakers hooked up today and was informed that i need new engine mounts, the extractors are in and fitted however the mounts r well and truly stuffed. i was quoted $200 for new ones to be installed including labour. does this sound about right? its a 99 vs ute manual if that makes any difference.
Not a bad price i guess.. do them your self and save some money... if you have a engine crane use it to take the weight of the motor, undo the engine mount bolts.. lift the weight of the motor off the mounts with the crane.. undo engine mount bolts to block.. put new ones in do it back up and your done. Should take less than a hour.
yea that'd b alright if i had a crane, dont have 1 but, yea i mite get it booked in then coz the engine had been hitting the power steering return line and actually worn it back heaps so that wen the guy went to take it off it opened up a hole in it. better there than trraveling around i guess.
if you dont have a engine crane get the ute up on stands then use a trolly jack under the motor to take the weight off the mounts ;-)
hahah deadset? id be up for anything that'll save me some money coz im on 1st yr apprentice wages. how much roughly are the mounts by emselves?
about $50 for a set... look on ebay theres heaps on there.
just make sure you use a block of wood between the jack head and the engine so you dont damage the sump
alright cool no worries, mite b a job 4 the weekend then
For $200 and no hassles I'd get the mechanics to do it as that is a very good price. Getting the left mount out from under the aircon compressor is guaranteed to skin your knuckles and turn the air blue. But if you want to save $$$...........
yea im still indecisive on which way to go about this.i'll have a think about it i think
If you go ahead and do them yourself just makesure to do one at a time.
Yeah I believe thats how you do it .... its much the same as sitting the engine on the floor on the sump, you are not trying to lift the car, just take the wieght off the mounts and bolts.
Ive just done 2 sets & Id say if you dont have a lot of experence on the spanners then pay the $200 & save your self the head ach
A simple message to ford owners,
Ok STEWY now
Yea use the sump as a jacking point, but not the centre of it.
Two blocks of wood is a good idea sometimes as it will take out any clearance issues of the subframe.
thats why you use a bit of wood between the jack and sump![]()
