Results 1 to 16 of 16
Thread: Weird idle problem
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Exclamation Weird idle problem
    Hey guys
    been having a bit of a weird problem with my ute, it only happens sometimes like it did it 2 days ago hasnt done it again until today
    when i go to start it up the revs go to just under 1400 and keep going higher and higher, ive check alll hoses for a leak there all fine, it has a mace 69mm tb with a delco tune to suit, the IAC has been cleaned spotless
    i was thinking maybe it mite be an ecu problem, i was going to disconnect the battery for a while n see if that fixes it, but like i said before it only does it sometimes warm or cold doesnt matter, also i have to shut it off cus it keeps reving higher then i start it again and its fine, only once after starting it again it did it
    anyone have an idea whats going on? its got me stumped
    thanks guys
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    4.2 vt executive
    Aug 2009
    my vt was doing that it ended up being the sensors on the tb i changed both of them and it hasnt done it since that was about 3-4 months ago
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Could be a BCM fault or a faulty TPS.
    Did you clean or take the TB off recently?
    Or has this started out of the blue?
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Jesterarts View Post
    a little while ago i put the Mace tb on with the tune to suit and about a month later it started doing it, also forgot to mention it only does it in Park when i stop at lights in drive it hasnt done it once
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by customvt View Post
    oh true im hoping its something simple as that
    VS Super6 Utility 5 speed
    Aug 2005
    Cairns, Australia
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Michelson4301 View Post
    Maybe the Park-Neutral switch ?
    it doesnt do it in Neutral either only in park, im leaning more towards the senors on the tb, are they expensive to replace?
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    well just went to holden (car was fine both times i started it) they want 250 bucks for 2 sensors now is that a rip off or what
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Maybe just try the Throttle Body Positioning sensor first.
    With the IAC have you made sure it was put back in with less than 28mm from base (Where the screws go through) to tip?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Wombles View Post
    yeah, they want $154 just for that sensor
    VS.5L is offline VX SS
    VX SS 6spd....and....250cc Baby Ninja
    Nov 2009
    Ballajura
    hey mate try conventry's or repco. just picked up TPS, IAC and thorttle body gasket for $121
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by VS.5L View Post
    did you get urs from one of them places? i mite try repco
    Nov 2009
    Ballajura
    this is in perth but you'd assume the prices would be same across the board. i got mine from conventry's, repco had to order them in and im inpatient
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ahh lol we dont have conventrys here, hopefully repco will be just as cheap
  15. #15
    Nov 2009
    Ballajura
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    yea they were pretty much the same give or take 10 bucks
    awsome, thanks for ur info mate
  1. weird idle
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2007, 12:18 PM
  2. Weird problem......
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-10-2006, 09:30 AM
  3. VS weird Air con problem
    By -Davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 10:26 PM
  4. my weird problem...
    By raZel in forum Car Audio
    Last Post: 10-02-2006, 11:53 PM
  5. Weird Idle
    By LiLEd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2005, 12:29 AM
