Results 1 to 8 of 8
Thread: 97 VS Commodore Cranking but not firing
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Default 97 VS Commodore Cranking but not firing
    Hey Guys,
    My mate has a 97 VS Commodore. He was on his way home the other day and all of a sudden the tacho went right up, but the car didn't rev, backfired a bit then just went dead. It is now not firing, but is cranking. We have replaced the DFi Module, Ignition coils, Spark plugs and leads. We are now thinking its the CAS. Its not the fuel pump as its still Priming when turning it onto reads.
    Am I on the right track to it being the CAS?
    Thanks
    Mumbo
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vs commodore
    Oct 2009
    Tamworth NSW
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Hey Guys,
    Does the CAS need to be bolted to the Engine block in order for it to be working properly? Could a drop Valve be a problem?
    Thanks
    Mumbo
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The CAS has to be bolted in otherwise it will foul with the harmonic balancer and self-destruct. Two bolts normally hold it in. A dropped valve would not cause the tacho to act strange - usually you get a clattery banging sort of noise and basically the engine will stop. It would also make a hell of a racket when being cranked over.
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Thanks hako. It turned out to the Sensors on the throttle body the MAP and Throttle Position Sensor's (I think that's what they are)
    VS 1997 S2
    Jan 2010
    Hi i am having the same problem as mumboman with my 97 VS Commodore, I was driving it the other day and i took off from the lights and the car stared to make a horrible noise like a dropped valve or missing really badly, and also the tacho went up really high and quick but the car didnt take off it slowly gained speed. and then all of a sudden just died. but i cant get it to crank over at all not even manually it just makes a click like the solinoid on the starter motor trying to kick it over. Please help?
    vs commodore
    Oct 2009
    Tamworth NSW
    Hey bullet,start your own thread about your own problem,just click on new thread on the main VR/VS page.Cheers
  1. cranking not starting
    By bmcleod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2009, 08:43 PM
  2. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  3. cranking problems
    By jimbojones889 in forum General
    Last Post: 09-07-2009, 10:46 AM
  4. Cranking but Not Firing
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 04:25 PM
  5. 5L cranking time before firing
    By V85000i in forum General
    Last Post: 17-10-2007, 05:51 PM
