Results 1 to 4 of 4
Thread: vr just stalled
    vr evecutive
    Jul 2009
    Angry vr just stalled
    guys today i was on the hwy and had the aircon on and when i was at the lights i put in the netural and then just stalled and still does not fire up she cranks but on go. checked the spark, fuel pump and fuses are ok, any suggestions to my probs would appreciate it greatly.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd try reading the codes: Checking error codes VR/VS (Revised)
    and maybe pour some water over the CAS if it's still hot ( can fix temporarily)
    Also try pushing unlock button on key whilst key is in ignition. Also swap relaysd around under bonnet.
    If this is of no help pls give more info.
    VS SS V8
    Oct 2009
    Townsville, Qld
    check the map sensor... my sister had same symptoms... crank but no kick and it turned out to be that.
    vr evecutive
    Jul 2009
    Thanks guys for the info, found it was the fuel pump. Cheers
  1. need help vs stalled then shudering
    By [p]wrr-247 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2009, 06:21 PM
  2. VT2 Stalled!
    By lazza44 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2006, 06:44 PM
  3. stalled
    By tomtomcom in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2006, 02:22 PM
  4. car stalled twice on me!!!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2005, 08:58 PM
  5. my vp stalled at an intersection!!!
    By kuffy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2004, 09:02 PM
