Results 1 to 6 of 6
Thread: pulling apart the dash around my cd player
    04 VZ sv8
    Nov 2009
    Default pulling apart the dash around my cd player
    hey guys does any body know a link to show me how to pull my console apart around my cd player in my vs ute cause i got a problem with adjusting my aircon from cool too heat, cheers
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    04 VZ sv8
    Nov 2009
    i pulled the knob out that turns it between cool and heat and when i went to push it back in the little half circle bit that it slides into pushed back too far for it too slide on so i need to get in there to see if i broke it or not
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    strgas's Avatar
    Oct 2009
    ok i see remove your trim around your t bar first then you should see three screws in the lower dash surround disconnect any switch wiring and then the surround should come away enough to see the heater controls
    04 VZ sv8
    Nov 2009
    cheers dude thats exactly what i was after
  1. After pulling dash apart, indicator fuse keeps blowing
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 06:11 PM
  2. WTB In dash DVD player
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 04-08-2008, 02:32 AM
  3. Replies: 3
    Last Post: 13-10-2007, 01:52 PM
  4. Is it worth my while pulling the dash out
    By marcwest01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2006, 08:16 PM
  5. pulling apart dash
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 10:24 AM
