Just wondering how can u prevent your car from rattling when playing loud music? in my vs loud rattles come from inside the driver and passenger doors any options i can take
My son glued masonite to his panels with liquid nails - held it in place till it set.
Find rattle, put double sided foam tape between whatevers rattling. Rattle fixed. Too easy!
You need to find a screwdriver, pliers work too, sometimes it can also be done by hand... Find the Fused Audio Resistor Volume Dial, turn anticlockwise. Problem solved.
ummm the last one will help heaps thanks guys
dont worry i have a vr and it sounds like its about to fall apart it rattles so bad and thats just from driving down the road, but what Philthy said is pretty much all you can do
whats the difference between my missus and my blower??
well they both whine but the blower actually puts out
As Philthy says, you need to find out where the rattle is coming from. Take off the door cards and the plastic protector and see if any of the screws holding things are loose. If you have power windows I'd be checking the rivets that hold in the windows actuators. They break over time and you end up with the window falling into the door. Easy fix if they haven't all broken yet. Also put some sound deadener under the rear number plate.
get a few mates, find a bumpy dirt road and cruise up and down til you've found half a dozen rattles fix them then do all over again thats how i found most of mine
Take the door trims off and listen, it can be the window regulator scissor bit, dont know how you would replace it other than with a new reg. Power window conversion?![]()
