Results 1 to 3 of 3
Thread: VS/VT Booster Diameter
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Default VS/VT Booster Diameter
    Hi all
    In the course of my engine swap I put a brake booster out of a VS into my VR to go along with the VT brake booster (I had the VS one already). Turns out the VS booster is to large in diameter and hits on one of the coil packs (LS1). Just wondering if anyone knows if the VT booster is at all smaller in diameter?
    Cheers guys
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    If you get a booster from a VT that had an LS1, (ie: series 2) then you shouldnt have a problem? (in theory)
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. hole diameter for 6" speakers
    By azzfox in forum Car Audio
    Last Post: 27-06-2009, 01:24 AM
  2. fuel pump inlet diameter
    By hakhawk in forum General
    Last Post: 09-12-2008, 06:14 PM
  3. VSII Berlina Rolling Diameter?
    By Stressball in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 05:07 PM
  4. 15, 16, 17, 18, inch rims ?.. is it same trye diameter outside ?..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2005, 12:48 PM
