Results 1 to 16 of 16
Thread: heater stuck on?
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default heater stuck on?
    My car always seems to be blowing warm air into the cabin. But when i turn it to heater it gets EVEN HOTTER. to the point where i cant hold the back of my hand to the vent cause it burns. So cause of this my A/C is useless cause its fighting with already warmed up air and only gets a little cold, even on cold days its blowing warm air so somethings a miss.
    cheers fellas
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Heater tap stuck on? Try cable tying the control arm on it under the bonnet and see if it makes a difference.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    VY SS
    Jun 2006
    Albany
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The air mix door can be stuck open or more probably the adjuster is not set correctly.
    Down by the drivers foot rest there is the rod that connects to teh air mix flap. Take the rod out and make sure the flap is hard over forwards (I think) and then set the knob to cold and then snap the rod back into the adjuster clip. This should set the flap correctly. Then just check that the flap moves from 1 side to the other when changing the knob from hot to cold.
    You get the idea tho - if this flap is a little open then it will let the hot air into the system.
    Or it's the heater tap stuck open. Check the vac lines.
    and 3 Dangerous non ABS VN's
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go with what 88GreenVN says and add that make sure the flap thingo described above depresses a small black plastic button (this is the vacuum on/off switch) when in the fully cold position. Also you may find the clip is busted as it's plastic. Or you can cable tie the heater tap shut.
    vs calais
    Dec 2008
    VS L67 Ute III
    Dec 2008
    Adelaide, Hallett Cove
    mine is always hot at my foot well but thats cos i need a new heater core so does your car chew through the coolant? and is it ever wet at your feet?
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by admir87 View Post
    could someone describe which position the heater tap is when its shut
    The heater tap control arm is pushed into the heater tap itself, thats when its closed.
    The hall of fame:
    ಠ_ಠ
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i posted in another thread a couple weeks ago with pics and instructions on how to adjust the temp adjustment knob and flap control behind the center console. 99% certain that you have the same issue. as described by hako and 88greenVN
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs calais
    Dec 2008
    how about for us that have climate control units? im pretty sure there is no lever at the back
    Apr 2006
    Auckland NZ
    climate control is completely different. it uses a vacuum module under the dash to control everything. check the climate control thread stickied at the top of this section for info
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by immortality View Post
    that little valve actually has to be working for this fix to work. Mine wasnt. Push button down = heater tap still on.
    The hall of fame:
    ಠ_ಠ
  15. #15
    VS executive
    Jun 2009
    Air Con Question
    the 2 second solution in this thread just fixed mine , the valve just wasnt being depressed enough.
  16. #16
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Vee-ard View Post
    is there vacuum at the valve? check the hose going to the heater tap, may be kinked/broken or sqwashed? maybe a stuck heater tap
  1. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  2. VT Heater Stuck On
    By dennis228 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 11:27 PM
  3. VN heater valve / tap stuck on cold
    By moose in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2009, 08:45 PM
  4. CD Stuck
    By VZCalZone in forum Car Audio
    Last Post: 26-04-2006, 11:48 PM
  5. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
