Results 1 to 7 of 7
Thread: is 42 psi good for 225/45/17 tyres ?
    vx berlina
    Aug 2005
    gladstone
    Exclamation is 42 psi good for 225/45/17 tyres ?
    hey guys i have 42 psi in my 225/45/17 "s usually i only have 35 psi, but i watched an episode of top gear the other day and they showed what happens to low profile tyres which are under inflated ,it was scary.so anyway my tyres say they have a max psi of 50 , and as im going on a big trip saturday i thought a couple more psi wouldnt hurt ,i gotta say the car feels better with 42 psi as opposed to 35 ,what psi do u guys run ? cheers muz
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Depends on the tyre...
    I run 36psi... but mine says max 42 i think so yeah... if it says max 50, 42 should be fine..
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    should improve economy a little as it reduces rolling resistance. Some tyres react badly to high pressures though, ride goes to shiz. I put no less than 40 psi in any of my wheels (one with 19s, one with 17's). I do it to keep them safe
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by lyndon_breeze View Post
    35 psi, holden specifications
    Tyre specifications say otherwise, not every Commodore uses the same tyre. It's written on the sidewall. 35 would be the "comfort" rating.
    vy
    Mar 2009
    it comes down to how the tyre is wearing. if it is wearing the outsides of the tyre it needs a few more psi and if its wearing the middle your tyres they need a bit less psi. most commodores will wear the outside of the front tyres and the middle of the back tyres. so if u have 42psi in the front mite pay to have a few less psi in the back tyres! i had a vn v8 with 18" tyres and ran 46psi front and 38psi rear.
    N/A
    Nov 2009
    42 will be fine on a long haul... just remember that once the tyres are warm they will be up around 46psi..not a problem, just saying...
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
  1. good 18" tyres
    By Troy711 in forum General
    Last Post: 18-04-2012, 05:28 PM
  2. good tyres??
    By pjwooly in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-05-2009, 04:26 PM
  3. What really good tyres should i get?
    By adamc11 in forum General
    Last Post: 04-12-2008, 09:30 PM
  4. What tyres are good in 17?
    By Stooged in forum General Discussion
    Last Post: 14-07-2008, 10:26 PM
  5. WTB: 2 good condition tyres
    By JD in forum Swap / Wanted to Buy / Trade
    Last Post: 27-09-2007, 02:04 PM
