****ing guys at the rego place, did and actual check of my car, and wont pass my car unless i get a right engine mount, is there a right and left one, or are they all the same
Tit-Tit-Titian™
for v6's mounts themselves are same same, vn through to vy left or right
can't say for 8's
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
A sheared engine mount can allow the engine to slide forward/sideways in a panic stop or even when cornering hard. Imagine the powertrain just rolling around in a roll-over. In an extreme situation it can shear the brake lines and kill your steering.
But to answer your question, left and right are the same but the rear is different. The VS has "hydraulic" mounts which are filled with some sort of fluid to smooth the vibrations so if you want to keep it original get the specific VS ones.
