Results 1 to 8 of 8
Thread: Air Con Question
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    Default Air Con Question
    Just noticed after yesterday been 40 that my air con was fairly average and the air only really came out from the centre 2 air vents , the side doors blow out weak air and the back 2 couldnt even feel much at all......just wondering if this is normal for all vs
    vs commodore
    Oct 2009
    Tamworth NSW
    If its working good the air inside the car should be about 10 - 15 degrees cooler than the ambient temp.You will find it will work better with the fan speed on 3 than 4.
    94 VR Statesman
    Aug 2006
    despo i have the same problem in my vr stato.. im thinking of going under and re foaming the connections in the vents see if helps ill keep posted on how it went
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If your air is not as cold as it should be the first thing you need to do is check that your heater tap is turning off....otherwise you are mixing hot and cold air and getting warm air. Check by feeling if the heater pipes under the steering wheel above your left ankle are cold with the engine running. If hot that mean the tap is not turning off. This is a very common problem. It should also be set to 'recirc' not outside air.
    VS executive
    Jun 2009
    ive got the same problem and im not sure if im just going too bypass the heater tap or actually try and fix it (no suction coming from the tiny hose that closes the heater tap)
    and if i do bypass the heater tap is there going too be much coolant left in the heater core etc.... i mean enough that ill have too top up the coolant.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've attached 2 pix - the first one is the switch in the off position (this turns heater tap on) and the second is with the switch in the on position (this turns heater tap off) To the left of the pix you can see the 2 vacuum lines going to this switch. Also note that my hot/cold lever is off the flimsy clip which I will now hardwire!
    Commos with climate control have a different setup.
    Re question on coolant left in heater core - will make no difference as you are neither gaining or losing coolant.
    Attached Thumbnails Attached Thumbnails Air Con Question-hotvacswoff.jpg   Air Con Question-hotvacswon.jpg
    VS executive
    Jun 2009
    Quote Originally Posted by hako View Post
    just what i needed thanks.
    i just fixed my aircon with a piece of cardboard of all things , the lever wasnt depressing the valve in enough by about 2 mm ....... i love this forum.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by pillzor View Post
    I love this forum when people say they fixed their problem
LinkBacks (?)
  1. 07-02-2010, 12:42 PM
  1. Not another cop car question!!
    By Colby844 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-12-2008, 06:43 PM
  2. One question.........
    By CSP in forum The Pub
    Last Post: 20-12-2008, 10:44 PM
  3. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  4. another oil question...
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 09:18 AM
