I have a VR commodore V6 that needs it's water pump replaced, I'm just wondering which is the main thing to unbolt, the tension pulley itself, the alternator or the P/S pump to lossen off the belt to the water pump.
Any help would be greatly appreciated.![]()
First loosen the bolts holding the pulley to the waterpump, then put a ring spanner on the tensioner pulley and turn it anti- clockwise to remove tension from the belt allowing removal of the belt. The rest is straight-forward. Good Luck.
