Results 1 to 6 of 6
Thread: Engine light likes to come on... sometimes
    VS Executive 3.8 Eco
    Oct 2005
    Default Engine light likes to come on... sometimes
    I was driving today and after about 10min of driving my engine light came on. I got to my destination about another 10min later with the car just being normal. When i went to leave to come back on i turned the car on and no engine light. Sure enough though about 15min later it comes back on again after driving. Did an error check when i got home and got a code 12, maybe my code 12 means un-normal?
    any ideas?
    my theory is my car does not like revving for long periods of time, thats partially my fault since i installed 3.9's
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Code 12 means normal mate, and it will repeat it self 3 times before it goes on to any "un-normal" codes.
    Test it again and let it run through the code 12 3 times and see if it come sup with anything else.
    Check It Out
    My 93' VR Executive
    Oct 2005
    my patience was not a virtue. came up with code 19
    Code 19 - Throttle Position Sensor (TPS) stuck
    is this a problem? and how do i fix it
    vs commodore
    Oct 2009
    Tamworth NSW
    Replace the TPS.I'm not sure they can be fixed.You could try pulling it off and see if theres any gunk built up around in it etc,and try giving it a clean up.Im pretty sure though that these are just a "throw-away and replace" item.
    VS Series II BT1 wagon
    Apr 2009
    Internally, TPS are just a series of small switches which let the ECU know if youre at idle, full throttle or backing off. When I opened up my Daihatsu Feroza's TPS, the contacts were very thin (1-2mm max) and I could see them becoming jammed if one ever bent/fatigued.
    Luckily ours are Bosch, common and easily changed over should replacement be needed.
    Oct 2005
    sweet. just wanted to be sure my car wasnt gonna blow up on me
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  3. Little Johnny likes to gamble.
    By lgnd3800 in forum Jokes/Humour
    Last Post: 04-02-2008, 03:08 PM
  4. This hot chick likes to be told what to do!
    By The1985divo in forum Jokes/Humour
    Last Post: 03-04-2007, 08:06 AM
  5. who likes big brother??
    By Sabby in forum The Pub
    Last Post: 01-12-2006, 10:28 PM
