Fixed Axle LSD centre into IRS diff will it fit?
You Must Always Remember to Blow on the Pie
""Safer Communities Together""
the diff centres are the same
yep they will fit
Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
My VS CLUBBY!
237.2RWKW - 318.1HP - 926.4 NM
thats awsome il start pullin mine old utes diff apart for the my new calais irs diff!![]()
Yeah as long as its Borg Warner 78 Series should be fine
100 percent different, you cant put live lsd center into irs lsd. first the lsd carrier on live one is lower compare to irs [ you know where the crown sit] second inside the irs lsd have groove so when you put in the cv axel joint it lock there, while live lsd dont have them. it will come out.
