well i went to check tranny oil and i was going to unlock dip stick when i did it the whole dipstick pipe came of so i know i need the bolt for it but the rubber grommet that sits in the hole that it goes in to tranny is broken any one know what this is called and where to get one and cost cheers guys
go to pick a part and get one ;-) the bolt that should hold it on is actually one of the 6 transmission bolts that holds the gearbox on... if its missing i would get it replaced asap.
the bolt that holds the dipstick on is also one of the transmission bell housing bolts
its separate bolt it only holds the pipe and im not planning on driveing it till i get new rubber for the bottem of the pipe just need to know where to get one and how much they are and what its called
Holden mate.
Sorry don`t know the part name.
When you discribe it they will know what you want.
I`m guessing about $10 for both mybe.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
cheers for that
you got holden dealer on the island?
at wonnthagi bout half hour away i go there 3 times aweek any way so will drop in
