Results 1 to 4 of 4
Thread: advice needed
    vh sl/x wagon
    Dec 2009
    Question advice needed
    g'day i need a bit of advice to disconnect the ignition immobiliser at the moment i have to wait 40 min with the ignition on and then and only then the car will kick over so if anyone could help me out i would be gratefull cheers.
    vs commodore
    Oct 2009
    Tamworth NSW
    You will need to get a new key fob and get it programmed at holden.I dont think theres any easy way of disconnecting or bypassing the immobiliser,only what you have been doing,waiting the 45 minutes.Is your key fob's battery flat?.With some VR keys,you can replace the battery in the fob.
    vh sl/x wagon
    Dec 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go to a wrecker and get a BCM and a key/remote to match. This would be cheaper than buying a new key/remote and getting it programmed plus if the one you have now doesn't work it may be the BCM that's buggered.
  1. VR advice needed
    By ladyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2009, 10:19 PM
  2. Advice needed! (What to buy)
    By Trei in forum General
    Last Post: 01-02-2007, 01:20 AM
  3. HELP, advice needed?
    By wadeson88 in forum General
    Last Post: 29-01-2007, 06:56 PM
  4. Advice Needed
    By Burnie in forum Car Audio
    Last Post: 17-08-2005, 08:23 AM
  5. advice for who needed
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-07-2005, 05:42 PM
