Results 1 to 12 of 12
Thread: fuel economy
    vs ss
    Aug 2009
    reservoir
    Default fuel economy
    i just done 90 kms and used like 38 litres
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    vs ss
    Aug 2009
    reservoir
    i checked no leaks at all i also got a mate to check fuel pressure lines and he said the pressure was fine
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    is there like heavy black smoke coming out the tail pipe?
    Next to check pull the plastic engine cover off and check for leaks around the fuel rails and injectors.
    vs ss
    Aug 2009
    reservoir
    checked that also the car seems to be drivning fine except for this one little lag when i chuck u turns it does my head in it feel slike its about to stall on me i seriously am puzzled
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    well the fuel has to go somewhere it's either leaking or using it, youve confirmed it's not leaking anywhere and the fuel pressure is good, if it's burning that much fuel it would have to be blowing black soot out the back pretty badly. 38Litres per 100km is well over the useually average of 10Litres per 100km, is the car running and idling fine?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Didn`t you just put in a new diff ?
    And didn`t get the right gear ratios ???
    Just a thought.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vs clubsport
    Mar 2009
    brisbane
    is this at the pump or is your dash saying you have used this much
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    VR Series II Equipe smokey 3.8 + clunky Auto
    Jul 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    38 litres in 90KM with a 5litre V8 and a very heavy right foot is probably OK. It's only a little over double city cycle economy and I'll bet my left n*t that it ain't being driven by Grandma.
    vs ss
    Aug 2009
    reservoir
    Quote Originally Posted by hako View Post
    i thought that as well so there is no leak and i did change the diff but i found out that it was 3.08 gear ratios everything semms to be running fine a little hooning around but not enough doto do that could the oetrol pump be dodgy
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the petrol pump was dodgy you would use LESS fuel. You are feeding 5 litres of Detroit iron which will drink about 50% more fuel than a V6 driven with a heavy foot. In the old language you are talking about 8 to 10 miles to the gallon. My old Jag would get 14 MPG but that was a heavy 6 with twin SU jugs driven sedately.
    With a V8 if you want to feel the power you pay with fuel. Enjoy it - I'd love a V8.
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2012, 05:14 PM
  2. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  3. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  4. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
