Results 1 to 7 of 7
Thread: altrernator problems
    vs ss
    Aug 2009
    reservoir
    Default altrernator problems
    im also having problems with my alternator does the v6 reg fit on the v8 alternator an is that the only thing that goes wrong with alternators
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yes there are both re60 regulators
    and no, theres heaps more that can go wrong. slip rings worn to far, diodes/rectifier plate burniing out, fields burning out
    vs ss
    Aug 2009
    reservoir
    i got the new regulator from pinch a part they had a brand new alternator sitting there and the bloke gave me the reg and put mine back in there so got the thing for a bargian but it didnt seem to help at all i found out my actual problem though the alternator seems to be working fine but as soon as i switch the headlights on it drains the battery wierd huh. my battery is brand new my regs are as well. it doesnt struggle at all to run a mono block and a 2 channel amp but not my headlights
    vs commodore
    Oct 2009
    Tamworth NSW
    I'd just replace the whole alternator.And check the wiring coming out the back of the alternator.The wiring can corrode inside its cover and causes a bad connection,usually the light on the dash will come on though when this happens.
    vl 308
    Jan 2010
    tamworth
    Default vl 308 alternator number or amp size
    Hi guys i have a vl bt1 its unfortunately but still fortunatey was previsoly owned by a semi pro drag racer and a lot of parts have been frankensteined together iam just going threw all my problems with it and trying to get it back to a street driveable vl and what iam after is the alternator thats on it is only a 45amp and in my short experiance with engines it just sounds to small for a 308 so could anyone tell me if its the write size or is it to small any help would be aprrecaited. oh i do love the car it looks good goes incredablely well but iam bringin it back to street i will put pics up soon Cheers to all
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi 308vl,you should start your own thread.This is someone elses problem that they want help with.Click on "new thread" at the top of the main page to start your own thread about the problems you are having.
    VS Acclaim V6
    Jan 2010
    hmm thats odd that it can run your stereo fine but not the headlights.
    id be leaning towards something faulty in your headlight wiring.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. Problems with Air-con
    By Degeko in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2006, 09:27 PM
  4. oil problems
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 09:56 AM
  5. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 08:50 AM
