Results 1 to 14 of 14
Thread: Instrument Lighting.
    VE 08
    Sep 2008
    Default Instrument Lighting.
    Hey guys, my son has just bought a VR Stato and the lighting on the speedo/tacho on the dash isn't working. Actually none of the lighting works on the dash. I've checked out the fuse and all "seems" ok in that respect.
    He asked a mate for some advice and he said to replace all the lights behind the instrument panel. I was thinking it's strange to lose all ya lights at once, i've never seen this before in my 30 years of owning cars, so i'm thinking something other than that.
    I had a play with the slider for the dimming off the lights (the one on the headlight switch) and it's kinds wierd, it doesn't really slide, it just kinda flicks from top to bottom which doesn't seem right.
    Has anyone else had this issue ???
    Any help would be much appreciated.
    Cheers.
    Danny.
    vx gen111 wagon
    Jul 2009
    perth
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Danny,
    With the dimmer switch, hold the slider for a couple of seconds up until you reach the required amount of lighting.
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    VX SS
    Jan 2009
    all the lights may have gone out at once, it does seem strange, but it is possible. As for the dimmer switch, im pretty sure they only have 2 settings, dull or bright, which is why it only flicks to 2 spots.
    VE 08
    Sep 2008
    Cheers for the replies guys.
    Yes Dave everything else lights up, just not the instr panel.
    Sera i'll give that a go.
    Hard, i never thought to try that.
    Quick update, spoke to the guy he bought the car off and apparently if ya hit a bump at the right speed and angle the Instr Panel will light up. So it looks like i'll be driving the thing round until i can find the right pothole and correct speed. LOL.
    Sounds like a s**ty switch to be honest, will keep ya informed.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Haha yeah id be taking a look at those switches. Could be a faulty wire/switch along there somewhere. It'd be a pretty easy fix.
    Check It Out
    My 93' VR Executive
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Scream View Post
    That's what it's like for most VR/VS's as far as I know, mine's like that. I think you can upgrade to the VT switch to correct it.
    As for the cluster, try hitting the top of the dash. I doubt they all would have gone out at once, they probably just faded out over time. Have a look around the how-to section for an LED upgrade how-to. Even if you stick with the T5/T10 globes, it shows you how to get to all the bulbs.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah I have a VR and they don't come with dimming lights it just flicks from top to bottom as you described.
    Did you test the bulbs with the 9V battery?
    Check It Out
    My 93' VR Executive
    VE 08
    Sep 2008
    I haven't as well Hardstyle, but i'm thinking of pulling the dash out today and having a look.
    Another update - Replaced the switch and it does the same thing, so while i got the dash out i'll check it right over.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    vr statesman
    Dec 2009
    hey guys screams son here i own the vr with the light prob.... i pulled the dash out myself and the instrument cluster checked all the globes they still fine not blown (15 of the little buggers) next step is wiring but after have no idea changed switch twice and still nothing so if i cant find nothing maybe time to see auto electrician....
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    hey mate, welcome to the JC
    something to check: the green circut ribbon on the back of the cluster, there may be a track or 2 that are damaged. or the metal connector on the plug itself may be damaged.
    might be worth taking a couple of photos and posting them up if theres nothing too obvious
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah take look for any bits that are faded heaps (perhaps from someone rubbing it on a bench) or a physical crack/brake in it.
    Check It Out
    My 93' VR Executive
LinkBacks (?)
  1. Instrument Lighting VX Series 2
    By dc-tfp in forum Electrical Wiring / Questions
    Last Post: 16-09-2009, 01:05 PM
  2. Sub lighting
    By DUK13Y in forum Car Audio
    Last Post: 18-08-2009, 06:18 PM
  3. Red instrument lighting
    By BruceSS in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-07-2009, 07:12 AM
  4. weird instrument lighting problem
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2009, 08:19 AM
  5. VS Berlina Instrument cluster LCD lighting - replacement
    By 6h84eva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2006, 12:57 AM
