Results 1 to 5 of 5
Thread: Air Con/Hazard/Demist switches dont light up
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    Default Air Con/Hazard/Demist switches dont light up
    Hey
    So my odometer stopped working today (found the how-to on how to fix that) but the 3 buttons havent lit up for a while now. Are these just bulbs or are the actual buttons stuffed?
    Thanks
    Originally posted by TVR-161
    " they dont have probs caz da cop chip is better den da normal chip yo, it makes shiz work"
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    After a while the do blow like any globe. they are little bulbs bout 2-3mm with a coloured cover over them. remove the 2 screws holding the dash surround and carefully remove the surround. this will give you access to the switchs. under each one are 2 screws which contain the bulbs, untwist half a turn and they should pull out, u can buy the bulbs from holden or any auto store, just take the globes with you so u know ur purchasing the correct ones.
    u may need to solder the new bulbs in if u go aftermarket the holden ones come with the screw/twist cap thinga.
    2003 VY S1 Acclaim
    Nov 2007
    thanks for the replies. while the dash is out, is there anything else i should look at doing ie routine maitence on anything etc? my air con doesnt do the floor vents at all, can this be done
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Just look at the green plastic backing on the cluster and make sure theres no breaks or cuts in it anywhere. Depending where the break is it can cause your cluster to do (or not do) certain things. Such as instrument cluster not lighting up etc.. So just make sure thats all good if you wanted to do "maintenance" as such
    Good luck
    Check It Out
    My 93' VR Executive
  1. VZ Hazard Light Problem
    By Zoltrix77 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-08-2010, 01:24 PM
  2. Odd hazard light issue
    By Semaj in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-07-2009, 11:33 PM
  3. Inside hazard light broken
    By WAC-988 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2008, 10:17 PM
  4. Lights for the rear demist. and int. light buttons not working
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2007, 09:38 AM
  5. Hazard Light Button - Flashes
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-07-2005, 03:36 PM
