Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Don't buy NGK sparkplugs
    vr berlina series 2
    May 2009
    Default Don't buy NGK sparkplugs
    hey guys just wanted to put a warning out there. bought some ngk spark plugs the other day just doing the change over. at first all was sweet after a little while the engine started misfiring and got progressively worse. taking the sparks out, gapping them and checking all make a spark couldnt pin the problem. bought a new set same problem but felt a bit different (did it at different times as the other ones). thought i damaged the leads so replaced leads to no array. bought some DENSO plugs works without fail. read on the net and i'm not the only one with thi problem on the vr/vs. so when buying plugs either spend the extra money or get the gm holden ones whatever you do dont get NGK.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    never had a problem with NGK plugs in 22 years in the trade and i would recommend NGK over most other brands , each to their own i guess ???
    vr berlina series 2
    May 2009
    yeah i guess so. i too have always held NGK in general in fairly high regard, just what happened though
    woteva's Avatar
    woteva is online now NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Used NGK for years without a problem.
    Got any links to others with the same problems as yours that you mentioned ??
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Have never used anything other then NGK, i think you just had a bit of bad luck, probably no needs to starting dissing em though.
    Mar 2009
    strgas's Avatar
    Oct 2009
    always used NGK with mod gap and no resistor for gas conversions over the years in many conversions without hassle .
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Random guy on the internet saying ngk are shit = 1
    Amount of times I(and most people i know) have done a service and changed the plugs with ngk and the car was fine = HEAAAAAAAAAAAAAAAAAAAAAAAPS!
    Sorry I'll continue to buy ngk
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by dlaponin View Post
    Thanks for the advise.
    Next time someone asks if they should use these plugs i'll tell them that i heard that a guy on the internet told me that they were bad
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    probably forgot to put the lead back on the plugs and wondered why it was misfiring.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    98' VS V6 UTE
    Nov 2009
    Quote Originally Posted by Vee-ard View Post
    haha to true
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Haha, like everyone has said, Used NGK when I changed mine. Fine.
    Just gotta make sure you put the leads on right and the spark plug is done up correctly.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    I use NGK and wouldn't change off of them. I've had the Bosch plugs stuff me around but never a NGK plug. You must of just been unlucky.
    strgas's Avatar
    Oct 2009
  15. #15
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by DeiCide View Post
    ive always used Bosch and havnt had any troubles
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  16. #16
    VX Berlina
    Mar 2006
  17. #17
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Quote Originally Posted by strgas View Post
    might have used to much anti seize and got it on the electrode ?????
    IMO there's no need to use anti-seize in street cars. If you're replacing them every couple of years and not doing them up too tight you'll be fine.
  18. #18
    VN Production Saloon
    Mar 2009
    Gisborne NZ
    Have used NGK plugs without dramas for over twenty five years, have had issues with champions but not the genuine made in the USA ones, BOSCH no issues but know fellow professionals who have. I AM a fan of DENSO plugs and they would be my top pick.
    1- Denso
    2- NGK
    3- Bosch
    currently running NGK's in 34G without any prob's and everytime i get in it i give it arseholes with just under 10:1 comp, headwork and a real fat delcowizzid tune, they come out after every meeting for a 'read' and go back in and i havent cracked a porcelain in years - probably will now though
    COOK COUNTY PERFORMANCE porting heads/manifolds & blueprinting. tuning by DELCOWIZZID
    WANTED SV3800 headers for 34G, need stockers as made by HM headers ~ used with patina prefferable for scrutineering
  19. #19
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    mate I had bosch in my VS, and completely useless, backfiring everything on LPG.
    As soon as i put NGK in there, she was sweet until I sold it ran perfectly... Same story with my VY. Was running on 5 cylinders on Holden plugs, and now I got NGKs in there and it is running perfectly... 15,000km on this set so far.
    Would use NGK every time and will continue using NGK everytime
  20. #20
    VR 5L ute
    Oct 2007
  21. #21
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Well I use bosch super 4's at the moment, but NGK have always been fine. Was your car built on a monday?
  22. #22
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    + 1 for using NGK. Bosch are crap IMO.
  23. #23
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    I went and bought NGK plugs last night just because of this thread. Car runs like a dream and feels new again. The old ones were definately past the use-by-date.
    The hall of fame:
    ಠ_ಠ
  24. #24
    VN Commodore
    Mar 2009
    Damn, auto barn told me i was the only one in the stores history with this problem. I serviced a mates vs commodore and put in NGK plugs and had the exact same problem, we tested all of them and found it was 1 plug out of the 6 that was messing up the engine. Visualy all was ok no cracks, gaps where right but 1 plug was just a piece of shit. Im never buying NGK again, Champion seem to go well.
  25. #25
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by Drift_Clown_VN View Post
    Did autobarn replace the item for you?
    so you got a bad plug.. it happens with everything in life. Autobarn even said that in the stores history, they've had one fail, i'd say that says enough about them.
    I've had em in my car for years, Dads run them in his mildy worked XW never failed. im a happy NKG user
  1. KLG sparkplugs?
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 09:49 PM
  2. Sparkplugs
    By Static89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2008, 03:34 PM
  3. woah.... sparkplugs!!!
    By zegerman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2006, 06:07 PM
  4. sparkplugs
    By executive_power in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2005, 04:43 PM
  5. vy 5.7 sparkplugs
    By wensky in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-08-2005, 01:54 PM
Tags for this Thread
